Douk Audio H5 Tube Preamp with LPF & HPF-designed specifically for A5
Douk Audio
Hello All ASR Members,
It's been nearly two years since the release of the Douk Audio A5. A big thank you to all ASR members for your valuable feedback and contributions to the A5.
After the A5 became popular, we received many requests from customers asking for a matching preamp. So today, we’d like to introduce the H5.
Here’s a quick overview of its features. For more details, please check the link: https://doukaudio.com/douk-audio-h5
Special discount for ASR members:
20% OFF for all ASR members interested in H5
25% OFF if you already own an A5 (purchased via our official channel, valid order proof required)
If you’d like to purchase, please send us a screenshot of this post (or your ASR profile) or the A5 order number to our official email: [email protected]
Thank you all for your continued support! Any questions, feedback or suggestions on our brand or products please directly message me!
hi I just ordered one, it seems like it has every possible feature you'd want in a desktop sized analog preamp! Can you let us know why 250hz and 180hz was chosen as the subwoofer low pass filter options? it seems high, people usually cross around 80hz. I have a muse dual opamp I can install when it arrives for fun
I just set up the H5 preamp, wow this thing is amazing! It sounds as good as my way more expensive preamp(don't want to name it because it's also a great brand). this thing is really tiny and saves a ton of space in my desk setup vs my other full size preamp. I already put in a MUSE 02 opamp before first use.
some pics of the insides
Why valves?
And why a need to change op amps?
Weird affectations both....
Reactions: RHO
Why a low pass filter when most subwoofers have that built in? Where's the high pass filter which is what is really needed? Plus those frequency choices are really weird.
the 250 and 180hz low passes work as 5.2V and 3.6V output settings, I think that's the use of the switch. man I'm really loving the sound of this preamp, the tubes are doing their tube thing really well. I kind of bought this preamp as a utility preamp for when I'm in between main full size preamps but it sounds so good I'm just using it as a main preamp for my desk setup
Why valves?
Because owners want tubes and want to change op-amps ... to improve the sound quality as we all know that's what tubes and op-amps do.
let's not draw attention to the 8 non-replaceable op-amps as they are not important for the sound
Where there is a demand the market follows.
An important design feature would be to have the op-amps socketed on the top of the case. This allows easy and "screwless op-amp rolling (TM)", so, for example, if it was Wednesday you could drop in extra imaging, on Saturday have bass lift. Or whatever is needed that is audible....
The 50k B-taper (linear) for volume control is a bit weird and should be A-taper (log) but one can easily turn a linear potmeter into a somewhat more usable semi-log taper with a 5k1 resistor. Could also be that pot is used with a volume control IC (but don't see one).
Otherwise it seems a reasonable neat design and even has MM phono input option.
Too bad the tube buffer can not be disabled.
What the heck is this effects box doing on ASR, which is arguably the worst platform to present it? I appreciate it's a subjectivists dream, but if valves are going to be used, do the effing thing properly - same with use of op-amps, which ordinarily don't need valves at all!
Continued apologies folks - I'm obviously no longer a hobbyist for such trinkets...
why do some people build their own speakers? Some people like DIY and/or tweaking.
I am one such... https://www.diyaudio.com/community/threads/fx-audio-tube-02-pro-basic-mod.436477/post-8308839
but I agree ASR is not a great place to advertise this kinda product.
review makes it look good except the low level channel matching from the pot.. and the slight high frequency rolloff of the phono input, which I don't use.. wish the pot channel matching was a little better
@Douk Audio Most people complain the Low Pass Filter settings are too high.
My recommendation is make a new version and remove the filter frequence switch on the rear panel and instead put a DIP switch inside the case on the PCB that allows more frequency choices (100Hz, 150Hz, 180Hz, 250Hz). For example the DIP switch used in the A5 amp for selecting LED colors.
You could mount the DIP switch on the bottom of the PCB with a hole in the bottom of the case for easy access to the DIP switches.
This reviewer IMO is pretty good if (big if on this site) you like *subjective* opinions without measurements...
