Douk A5 Budget Stereo Amplifier Review
Rate this amplifier:
    Votes: 12 3.6%
    Votes: 41 12.4%
    Votes: 164 49.5%
    Votes: 114 34.4%
Hello, thank you for your new suggestion regarding the A5!
I have passed your suggestion on to our product development team; they will carefully review and consider your ideas. I will share any updates here as soon as I have them.
Thanks again! :)
Since you’re open to ideas, here’s my 2 cents. I know you already have the D1 as the higher-end option, so I’m thinking specifically about the A5 as the budget/entry-level amp.
A few things I’d love to see:
  • Move the HPF knob to the back, like on the D1.
  • Ditch the glass top. Personally, I’d rather have the money go toward features than aesthetics.
  • Add decent Bluetooth. aptX HD would be more than enough for most people.
  • Bonus: a second set of RCA inputs with auto-switching.
  • Bonus: balanced inputs.
If you could get most of these in there and still keep it under $150, I honestly think the A5 could become the default recommendation for a budget starter amp.
Arylic has had some truly horrific reviews here.
Yes, have seen that. But it's not expensive and its practical. Basically using one remote for TV and Arylic with HDMI-cec. Oh, and it can be buggy at , both app and device. Fortunately, not often. I'm waiting for smart plugs so I could automate turning on and off BP50 and A5 at the same time.
Also I'm beginner so probably a lot of stuff regarding audio quality wouldn't notice as more experienced people
paired it with Arylic BP50 (ARC is a must as movies are primary use)
There are many ARC gadgets that will give better SQ, audibly transparent.
Not saying ditch the Arylic now, but next opportunity when expanding / upgrading.
If you want network based streaming, Wiim Ultra is highly respected here, I highly recommend that, more flexibility than the Wiims with speaker amp built in.
Honestly with a little more than the price of BP50 + A5 you could have got a WiiM Amp during the sales or secondhand. Leaps and bounds better than your combo.
Thanks. It's more or less the plan. Wiim is out of budget right now. Surprising there is not much devices where you are able to use your tv remote for volume control as most simple convenient way. Arylic was actually first I found locally, pretty cheap and ticked the boxes. HDMI extractors are numerous but you usually need to use their remote or turn the knob manually
A5 was 99$ with 48V/5A. Arylic somewhere around 70€ locally in Bosnia and Herzegovina. Wiim amp is 400€+ locally. Amazon price in pic. And to be honest when I started looking into putting something together never heard of it.
KanexPro AUD-DCODEARC-4K HDMI ARC Audio Decoder
Home Theater Direct HDMI-ARC-X
not as known
XOLORspace D62
personally I'd just save up for Wiim Ultra
Note that this path you are at the mercy of whatever the TV is doing to the signal.
To me a high price for convenience
Primary use is multimedia anyway. Movies on tv and projector. The whole this "project" started when my Yamaha Ysp-3300 sound projector died and just couldn't watch anything while using internal speakers in tv. So it was a little impulsive and "let se what I can use" situation
You need to provide more details on your context and needs. And even with 100% of the facts, value is subjective.
Does A5 provide all the features you need?
Does it provide all the output power you need?
Do you care about clean measurements beyond audibility?
What continent are you on? Or is self-importing from China OK?
Yes the a5 provides all the features I need and the output power. I am buying it for a nearfield desktop setup with the ascilab f6b. The features I need are highpass, subwoofer out , and if possible room correction, but the wiim is too expensive imo. Self importing from China is okay.
Just wanna know if theres any better bang for buck now.
Plan to use a smsl su-1 + a5/similar setup.
Certainly nothing in the same price range
DRC costs lots more.
So does Ampapa D1, which adds
balanced inputs TRS + Bluetooth 5.2 (aptX/aptX-HD)
remote control
12V trigger
OLED screen including VU meter
some say "better sound"
remote control
12V trigger
idk what i would do with balanced inputs and bluetooth honestly, so mostly those features aren't very relevant. Currently I run pc to optical converter to optical. My main concern is really just sound quality.
On the topic of sound quality, do you think I should maybe go for a used AVR? As they have audyssey too.
Better speakers and DRC will have 1000x orders of magnitude greater impact on that.
But require 10x the budget or more.
Just be sure about the power / SPL aspect
Just got my Douk A5. I measured with the HPF off, middle, and all the way to the 200Hz mark. I'm kinda disappointed the that the behavior of that filter really doesn't pull out all the low frequencies. Other than that, this amp sounds and works great for my desktop speaker setup.
That is exactly how it's supposed to work.
Do you mean the curve has gaps? Isn't the problem actually with your part?
