It certainly appears you're not very sceptical of claims that devices which effectively measure the same would still sound different...
Without properly conducted A/B testing we will never know.
That's because I've done it and heard it myself. I trust my ears more than measurements. You are free of course to do the opposite.It certainly appears you're not very sceptical of claims that devices which effectively measure the same would still sound different...
Everyone hears differences before they conduct level-matched and unsighted comparisons.
Which requires if you are going to compare properly two amplifiers one standard and one modified.
‘not everyone falls victim to cognitive bias,’ I think you will find everyone does.
Cognitive bias in not a conscious decision. Even if you go into a comparison expecting zero difference, you can still be subconciously biased to hear one. You cannot correct for bias by knowing about it, expecting it or in any other way than nullifying its influence by external methods like blind testing.I sorta agree with this, but it can be in both directions. For example I tend to be skeptical (negatively biased) about most things and most claims.
So my bias going into to many of these things is ... "this won't make any difference or nearly zero difference"
Which is also why I spend as little as possible on this stuff - because I don't want to waste my money on crap that has at most microscopic improvements/ROI
eg. I don't buy $70 opamps and $50 capacitors, $300 vacuum tubes, and $500 cables.
No *everyone* does not. Some don't have have sufficient hearing acuity regardless of everything else. And not everyone falls victim to cognitive bias.
And it matters what was modified and how much that particular mod affected the system's sound, and if the rest of the system is resolving enough.
If you modded so much that the modded one is essentially like a completely different product, most people easily hear a difference in a good system.
If it's just swapping two op-amps in one device perhaps no or perhaps yes, it depends on various things.
If the systems sucks, like many mainstream speakers do, then you likely won't hear a difference even with a highly modified device.
If the system is highly resolving you might hear a difference in just improving the power supply quality of a single device.
this has been my experience over many decades of Audio consumer, DIY, etc.
O rlyoh snap! you found my kroptonite. Memes always make me crawl into a corner and cry my eyes out.
Have you read Amir's review of the Micca RB42 bookshelf speakers yet?I was interested in this but noticed that there is no way to tell what number you are on for the high pass filter. It just shows 30 and 200, are you supposed to guess somewhere in between? I'm new to all of this and just trying to figure things out. I was looking into getting some passive speakers for my desktop setup. I already have a dac so just needed an amp and heard good things about this one but not sure how to properly configure it. Could someone help me understand how to make use of the high pass filter?
Also I only recently decided to go with passive speakers, I had done a lot of research on powered speakers because it seemed like it would be an easier setup. But after doing some more research it seems like I would just be paying more money for something that is going to break a lot faster. I've only found a few passive speakers that seem to fit my budget of under 300 dollars. I found these
Micca RB42 Reference Bookshelf Speaker, does anyone know anything about them? Would they work well with this amp?
If not I would love to get a few other recommendations. If possible I would like them to be shorter than 11 inches.
It's best to configure the high pass by measuring the response of the mains and sub, for example using a UMIK-1.I was interested in this but noticed that there is no way to tell what number you are on for the high pass filter. It just shows 30 and 200, are you supposed to guess somewhere in between? I'm new to all of this and just trying to figure things out. I was looking into getting some passive speakers for my desktop setup. I already have a dac so just needed an amp and heard good things about this one but not sure how to properly configure it. Could someone help me understand how to make use of the high pass filter?
Another review here. The frequency response looks pretty uneven. The directivity also isn't great causing the region around 3 kHz to dip quite a bit off-axis. At that price point, you might be better off with a cheap active speaker like the T5V. If it's got to be passive, the Micca MB42X G2 could be a decent low-cost option. You can search the review index for additional alternatives.Also I only recently decided to go with passive speakers, I had done a lot of research on powered speakers because it seemed like it would be an easier setup. But after doing some more research it seems like I would just be paying more money for something that is going to break a lot faster. I've only found a few passive speakers that seem to fit my budget of under 300 dollars. I found these
Appreciate the advice but I have a few more questions. First I don't have any measuring equipment, is there a way to figure out the high pass stuff by ear? Do I actually need a high pass filter at all? Looking around at speaker amps many don't even have one is it mostly placebo if I'm just a casual listener?At that price point, you might be better off with a cheap active speaker like the T5V
You don't need a high pass if you don't have a subwoofer. If you do have a sub, it usually has a low pass filter - sometimes an adjustable one. In that case, you need to match the low- and high-pass filters to get a smooth crossover region from your sub to your main speakers. You can probably roughly match them by ear by playing a sine sweep and listening for obvious loud or quiet regions in the bass. It won't be perfect, but it might be good enough.Appreciate the advice but I have a few more questions. First I don't have any measuring equipment, is there a way to figure out the high pass stuff by ear? Do I actually need a high pass filter at all? Looking around at speaker amps many don't even have one is it mostly placebo if I'm just a casual listener?
People often say that, but in the end it comes down to frequency response, directivity and distortion. Good studio monitors offer exceptionally flat FRs, smooth directivity and low distortion. That's almost always a good thing. The T5V in particular is a little bright, though. You can compare its estimated in-room response to good entry level HiFi speaker like the DBR 62 and you will see that the treble on the T5V is "hotter". But it also offers a correction switch in the back and the -2 dB position might already be enough to fix that. You will not necessarily need EAPO, but it never hurts to have the option to add some parametric EQ.Second that T5V speaker you mention it says that it is a studio monitor speaker. I've run into that moniker often when researching for example the JBL 305P Mkii gets mentioned a lot as a good speaker. But I was under the impression that studio monitor speakers were not good for casual listening and more for music production. Is that not actually the case? If I just want to watch movies, listen to music ect and I buy a studio monitor speaker will my experience be much different than if I had gotten a non monitor speaker? Will I need to use APO or something like that to adjust them? How difficult is that I really only know how to choose pre selected options in there.
That's an incorrect impression. Whether a speaker is marketed as a "monitor" or a home stereo product makes no difference -- it comes down its measured performance. FWIW, aside from my sub, the rest of my speakers -- all seven(!) of them -- were labeled "monitor" by their manufacturers, and they deliver outstanding results for both serious music listening and movie/TV sound....I was under the impression that studio monitor speakers were not good for casual listening and more for music production. Is that not actually the case?
The more recent versions of this amp have additional high pass filter markings at 35, 60, and 180 Hz. I tweak mine by ear.I was interested in this but noticed that there is no way to tell what number you are on for the high pass filter. It just shows 30 and 200, are you supposed to guess somewhere in between? I'm new to all of this and just trying to figure things out. I was looking into getting some passive speakers for my desktop setup. I already have a dac so just needed an amp and heard good things about this one but not sure how to properly configure it. Could someone help me understand how to make use of the high pass filter?
I'm in a very small and quiet bedroom sitting about 5 feet away from the speakers, it's an apartment building so I doubt I would be turning up the volume too loud in most situations. Thanks for the heads up though, I'll keep doing some more research and maybe I'll make a thread of my own when I have more options in mind.The more recent versions of this amp have additional high pass filter markings at 35, 60, and 180 Hz. I tweak mine by ear.
Look at main speakers that have at least 5.25 inch drivers - this will provide more seamless integration with a subwoofer as you will be able to set the crossover point lower, around 80 Hz or so. Maybe Something like Polk ES15 or Wharfedale Diamond 12 series.
With that said, I am not too thrilled with the A5. It sounds OK at lower volumes, but at higher volumes it sounds strained. For nearfield applications, it's fine though. For far field, if you like it loud, look elsewhere.
