Double Bass Array (DBA)
  • Thread starter Thread starter Deleted member 58670
  • Start date Start date
A DBA creates a 1 dimensional wavefront that's completely the same everywhere in the room (in theory at least), if you'd split that in left and right it wouldn't be able to do that anymore. Not that it matters though since we can't hear direction that low in frequency, and most stuff is mixed in mono anyways.
There are posts in the envelopment thread that point to research that contradicts these 2 assertions.
Which two assertions where contradicted in what thread?
The first two from this sentence:
Thread- the one about envelopment:
These bass arrays are for mono, not stereo
Any normal *BA is mono. Nils mentioned theoretical stereo bass in one of his articles. But the wonderful equalization disappears in most part of the room. Also, somewhere on ASR, we discussed a pair of perpendicular DBAs for stereo bass.
May it might be better to discuss general DBA issues in the @René - Acculution.com https://www.audiosciencereview.com/...of-the-double-bass-array-configuration.37943/ thread? Also welcome to my thread.
On the other hand, the discussion here is like a memorial to StigErik.
In very quick comparison, the DBA was preferred over four subwoofers, both in the standard and Kreskovsky configurations. Power equalization was roughly equal, and the influence of time and other (what? :cool: ) factors could not be ruled out.
Also in my thread is a link to Öllerer and Geddes' discussion on diya.
Difficult to see the benefit with DBA. Dirac Art works higher in frequency, and also uses the speakers.
Meaning one can achieve a great result in most rooms with a pair of floor standing speakers and two subwoofers combined with Dirac Art.
DBA also takes up space where acoustic treatment is needed for a high-end result.
I haven't read the whole thread but some of it, and from what I gather that thread brings nothing new; the lower in frequency you go the harder it is to localise it because when sound waves are so much longer than the distance between our heads, and yes most music is mixed in mono. But if you have something specific to bring from that thread then please go ahead.
Two floor standing speakers with subs can give quite even bass, but a properly setup DBA will give you perfect bass everywhere in the room which is something a pair of speakers and subs cannot achieve unless the room is heavily treated.
The first part:
"Two floor standing speakers with subs can give quite even bass"
It can yield super even bass and also great time domain behaviour. Look at measurements with Dirac Art if you haven't.
Second part about perfect bass bass everywhere in the room:
"Perfect bass" is not only what's below 80, 100 Hz or 120 Hz. Actually the upper and middle bass is more important than sub frequencies. This is were DBA doesn't do well. Dirac Art isn't perfect here either, but it goes at least higher in frequency. Both needs to be combined with treatment for a stellar result.
You're right that DBA, for the frequencies it works, it will work in a greater part of the room vs Dirac Art and multiple woofers. However, DBA does generally require a symmetrical room to get the same result everywhere. Something like a L shaped room would be different.
As for Dirac Art and multiple woofers; you can get it to work over a wider area and the more the woofers you add the bigger this area will be. But you're correct that it will still be limited. Which is a compromise I think most are fine with as we usually only do criticial listening at one place.
The first part:
It can yield super even bass in ONE spot, DBA can do it in all spots. If you only listen in one spot then of course DBA might be a bit overkill, but personally I want proper bass everywhere in my living room since I and my family more or less everywhere in there.
Tbh I think the upper bass is less important, I tend to dial it down a few dB because I think it easily muddies everything up. Instead I think the low bass is way more important to focus on since it's often harder to get it right, but mostly because it's that deep bass that makes everything sound so awesome ;)
But I don't think many people do DBA for that upper bass anyways, if I'd every do a DBA I probably would go that high up. But yeah you need a symmetrical room, but if you do cover that rooms front and back wall with enough subs you'll get better coverage upwards, it's just a matter of density. I mean fill the walls with thousands of 1" tweeters in a honeycomb pattern and you'll get perfect treble everywhere ;)
The first part:
I think the time domain correction of DIRAC ART is a very interesting subject. My understanding from reading various sources (which are speculative as DIRAC is a black box) is that DIRAC ART does not look to set up the speaker system to accurately recreate the time domain information from the original recording but rather it creates a "target" impulse response and then creates filters to force the speaker system to match this "target" impulse response. This of course "looks like great time domain behavior" on graphs and it may very well be a good strategy but it also may not accurately recreate the time domain cues/ information from the original recording. Whether or not this matters is an open question and probably will always be due to the nature of time domain audibility which is inconclusive. In regards to this conversation I don't think we have enough information to say DBA or ART is "better" in the time domain although I think you can safely assume they are going to yield different results.
1. It will be mono. Although, perhaps, not quite ordinary.
2. Not the highest frequencies, interference will occur.
3. Any and every object in room will destroy the theoretical ideal. Even if continuous transdusers are used.
Just for fun:
AFAIK, the "wave front" only "combines" (sums to equal) after a certain distance.
I've personally come to realise that "off center" bass is bad. So if I have 1 sub that slightly on 1 side of the room - my "face gets hot" on that side (literally).
"combines"
The previous page quoted René's simulation.
And anyone can (with some inconvenience) draw a primitive 2D model in HornResp. In the real world, any object disrupts the plane waveform at a high enough frequency. This is another limitation on the usefulness of DBAs at frequencies above "traditional subwoofer frequencies":
Even a continuous radiator, the entire moving front wall, won't prevent this:
But what's the math on this? Having a human standing in the room what's the highest frequency that can be played without interruption? Seeing that a 100Hz sound wave is 3.4m long and a human occupies maybe 0.3sqm it should be fine quite a bit higher than that, but how much higher?
Absolutely. But you should have in mind that those obstacles in your 2D-simulation are quite massive, like 2-3ft (≈1/2 wavelength) diameter trunks from floor to ceiling. A chair or a table or even a person has a much lesser impact.
And over the length of the signal there are 3 wavelengths, so if the “room“ is ≈6m long this would correlate to 150-200Hz, already well above normal sub range.
What are the frequencies in your simulation?
Wavefront simulator is not very convenient to use. My pictures show 12 kHz and a 1 mm element size, meaning the transducers are 6 mm and the rest is proportional. The width (or height) of the simulation is approximately 50 elements. For example, this is a room 5 meters wide and the frequency is 120 Hz.
10 cm element, 100 Hz:
Obstacles are quite massive and frequency is quite high to demonstrate effect. Questions about perfection of the simulation can be asked to the developer, I am not an expert.
SBA with passive absorber at rear wall is likely less sensitive to waveform shape, but also less effective at absorbing low frequencies. Nils settled on the passive absorber. He needed moderate and smooth low-frequency equalization.
