lke7777777
- Joined
- Dec 8, 2018
- Messages
- 21
- Likes
- 0
anyone can share their setting in foobar that can be play DOP file in Topping D50..thanks
Why not native DSD?
As for sources themselves, generally you'll find DSF and DFF files ripped from SACD's.
You'd have to have intimate knowledge of the mastering process.I believe that's not what Ray was asking. How do you know that DSD stream from SACD was not converted from PCM?
So...anyone can play dop on d5o or not..thks..any setting for d50 sharing here..thks
how to connect phone to d50..thanks
vol to max already, but still only..sss.ssss output. topping device shows 176.4khz but only..ssss.ssss ...pls helpMake sure your volume settings are at maximum in windows sound manager and topping dashboard/driver. Dop will only work in max vol setting.
Bringing down the volume will destroy/corrupt the embedded info for DOP
Below guidance to setup foobar for dsd dop and native :
https://diyaudioheaven.wordpress.com/digital/pc-software/foobar-2000-for-dummies/
https://diyaudioheaven.wordpress.co...-part-3-new-experimental-sacd-plugin-v-0-9-x/
https://diyaudioheaven.wordpress.com/digital/pc-software/foobar-2000-for-dummies-part-2/
toppinh d50 using.
for device output there have a huge of selection..which one is correct
asio driver have huge of seletion too...which one is correct
from sacd out mode too...dsd or dsd + pcm only
anyone using topping d50 here can really play dop normally...
