Hi all, two questions here -
I'm after a DAC/amp which can run my DCA Aeon Closed RT's from my work computer, unfortunately IT will not permit any drivers to be installed.
Alternatively if I can run it from my Samsung phone whilst simultaneously charging that would be fine. I see you can purchase this Y splitter from E1DA, does anyone know if this will allow my phone to charge whilst listening through the DAC? Or would it at least power the DAC so my phone battery isn't drained too quickly throughout the day? Either option is fine.
I think I prefer the Hidizs S9 Pro over the E1DA but am concerned at how much power it uses. I listen at relatively quiet levels in the office so may not be a concern.
Any direction would be much appreciated.
Further to this, I caught a thread where apparently the standard Dummer cable from DCA is 4 core down to the connector, meaning in theory I would be able to swap out the single ended connector for a balanced 2.5mm/4.4mm TRRS, has anyone done this before - before I go cutting off the factory connector?
