heita0
- Joined
- Oct 16, 2021
- Messages
- 11
- Likes
- 2
Hello! I am trying to set up the following electronics to my PC:
I need the dedicated Speaker Preamp because I would like the option to add a subwoofer to my speaker system with a crossover frequency I can control. The NAD M12 preamp provides this feature. It also provides room correction, which can be great. However, it has a built-in DAC—will this replace my dedicated DAC in the speaker chain if I feed it XLR inputs?
These are my questions:
1) Is DAC>Headphone amp + Speaker Preamp>Speaker Amp the correct organization?
2) Will using the speaker preamp for subwoofer crossover and room correction result in the preamp's DAC being used instead of my dedicated DAC? The dedicated DAC I will use is very high quality, so it is a problem if adding the preamp to the chain essentially takes its value addition out from the speaker chain.
- DAC
- Headphone Amp
- Speaker Preamp
- Speaker Amp
