Does such an amp excist ?
gasolin75
Denmark
I have a system where i would like an amp with:
pre out in case i wanna buy a power amp or active speakers
Sub out because i have one and use it
Now to the tricky things, demands
High pass filter so i can take the load out of my speakers triangle (not super important if the amp isn't to power full, can use all of it's power)
Finally subsonic filter so i can take the load out of my speakers, sub when using my turntable (excesive movement of the woofer)
400 euros or less, basically the price of a Wiim amp or Marantz pm 6007
Subsonic filtering is usually the job of your phono preamp.
Are you looking for an Int Amp with built-in Phono Pre?
Or do you have an external Phono Pre, but for some reason it's missing a subsonic filter?
Some integrated amps has as subsonic filter, i don't have a subsonic filter
I wanna try to see what option there is for all in one amps so i don't have 2 unit's an amp and a phonostage with subsonic filter
I also wanna have the option of using active speakers in case im going into active speakers (then high pass filter might not be that important since some active speakers has a hpf or im simply not gonna use my sub)
If im lucky i can find an amp for what a used pro-ject phonostage with subsonic filter costs, like the box S2
Phono stages used to house the ‘rumble’ filter.
