Well, on this one I'm sticking with my constant-delay crossovers and continuous phase response.
There is no interest from the industry (and thus AES etc) to show audibility of phase distortion.
But we are in the lucky position to create dependable evidence ourselves with quite little effort, relatively speaking:
- Take an existing decent setup (good speakers, good room with proper balance of absorption and diffusion, of course acoustical symmetry)
- Apply professional DRC (like Acourate etc) to it at the LP, to create flat (to target) mag response and min-phase'ish phase response
- Make long-term AB comparisons (and then ABX tests once the learning curve has settled), with introduced global phase distortion like what regular speaker XO would introduce (same on both channels, of course), listening for a number of effects like timbre change in the bass, speed of bass transients, soundstage aspects like perceived size and sharpness of phantom sources), etc etc
- Draw your conclusions
Sure thing, don't mean to hog the floor.If you do care about phase more, then conduct your own formal experiments and come back with that data. Otherwise disagreeing for the sake of what one feels in their belly is not going to get us anywhere.
Yes, I am more in the latter team. From my personal experience with the WiiM an the SMSL D6s (a Friend kindly lent it to me), I can say that there is (via Roon) at least an objective tiny tiny difference between direct use of the WiiM versus WiiM digital out to SMSL D6sNothing to complain at audibly level by my needs and capacities, but numbers are what they are.
123 SINAD of Topping D90 III is better than 113 WiiM Pro Plus, what is audibly or not I don't know.
I found diverse answers in ASR, some of them arguing imperceptible over 120 SINAD and other enough over 110.
Wrong link? The 3e has 100 dB SINAD.It's the sole SINAD number that does not tell the story I want to point out.
For example this popular amp has a 70dB-80dB SINAD at 5kHz but a good SNR. It won't be a problem at all in its good operational range and no one is reporting such.
(I admit I always tend to think speakers, so... )
When I wrote the last paragraph I didn't calculate how much SNR I needed in my configuration, now I realized that 80 dB SNR should be enough even in the most exigent conditions.Yes, I am more in the latter team. From my personal experience with the WiiM an the SMSL D6s (a Friend kindly lent it to me), I can say that there is (via Roon) at least an objective tiny tiny difference between direct use of the WiiM versus WiiM digital out to SMSL D6s
When the next song plays, there’s a tiny tiny barely audible „klick“ bevor the Song Starts. Nothing to make a big thing about. But with using only the AKM Chip inside the WiiM, the tiny tiny „klick“ was not there. It was flawless.
This was the objective difference!
The digital signal has so much shorter Signal Path to go, if it stays inside the WiiM, so my brain tells me on the „subjective“ side also that the sound was more musical and more natural and less harsh by just enjoying the WiiM Pro Plus.
In my case the 113 dB topped the 120 dB. But who knows, perhaps it was a synchronization Problem with the SMSL D6s and that causes the tiny sound degradation also…….
??? If there is no music playing, then -110 dB between 2 and 5 kHz would be audible by itself.To listen any noise at 110 SNR you should listen at 140 dB which is very unlikely (and dangerous).
You missed the frequency in the postWrong link? The 3e has 100 dB SINAD.
-110dB on it's own???? If there is no music playing, then -110 dB between 2 and 5 kHz would be audible by itself.
When played at what level in SPL at the ear, Amir???? If there is no music playing, then -110 dB between 2 and 5 kHz would be audible by itself.
You have to take into account the spectral content of typical room noise—It's mostly low frequency rumble. I've mentioned before that I can hear a 2kHz-5kHz sine chirp down to approx. -4dBSPL in my listening room. That was with my head turned a bit to maximize ear gain in that range.I think not so much, at least my setup peaks at 110 dB @ 1m and my room is not one of the most silent, let’s be optimist and put 35 dB ambient.
I’m listening at 2 meters, so can expect reasonable 105 dB peaks, that means I would be well deserved with the mentioned 70 dB SNR.
Am I right?
I supposed a 30 dB ambient noise and 140 dB listening levels to justify a situation in which 110 dB SNR will be necessary, in the case if the rest of the chain doesn’t impose their own noise.??? If there is no music playing, then -110 dB between 2 and 5 kHz would be audible by itself.
Neither is appropriate. Your noise floor varies with frequency and there is no home gear that can produce 140 dB of dynamic range.I supposed a 30 dB ambient noise and 140 dB listening levels to justify a situation in which 110 dB SNR will be necessary, in the case if the rest of the chain doesn’t impose their own noise.
Of course not. The DAC noise is amplified by the amplifier. That's why many people use resistor-based volume controls (variable resistors or relays and fixed resistors), which reduce the DAC noise. -80 dB noise is easily heard by many people from a speaker system at a distance of two meters. Even I, an elderly person with tinnitus, can hear -75 dB. That's why I wouldn't even consider buying a DAC with noise worse than -100 dB. And preferably no worse than -110 dB. For modern DACs, this is not a problem at all, including ultra-budget ones.In well isolated headphones maybe I can listen -110 dB, but I’m pretty sure that for my setup (max short term 105 dB at my listening distance) is enough to have an 80 dB SNR DAC because my room is quite noisy.
Was a hypothesis.Neither is appropriate. Your noise floor varies with frequency and there is no home gear that can produce 140 dB of dynamic range.
Hmmm, that gives me another possibly setup alternative to current (WiiM Ultra to Genelec G Threes) that is WiiM Ultra => Ifi Zen DAC signature (which has a physical attenuator knob) => Genlecs G ThreeOf course not. The DAC noise is amplified by the amplifier. That's why many people use resistor-based volume controls (variable resistors or relays and fixed resistors), which reduce the DAC noise. -80 dB noise is easily heard by many people from a speaker system at a distance of two meters. Even I, an elderly person with tinnitus, can hear -75 dB. That's why I wouldn't even consider buying a DAC with noise worse than -100 dB. And preferably no worse than -110 dB. For modern DACs, this is not a problem at all, including ultra-budget ones.
I read 5 Watts instead of 5 kHz, so I thought you were referring to @amirm‘s first graph (on top of every test of any device). You are absolutely right!You missed the frequency in the post
Look at the Frequency vs distortion chart.
My answer of 70 was more about the fact that SINAD is not enough.Hmmm, that gives me another possibly setup alternative to current (WiiM Ultra to Genelec G Threes) that is WiiM Ultra => Ifi Zen DAC signature (which has a physical attenuator knob) => Genlecs G Three
Was discussed in another thread, but most members consider the difference inaudible because WiiM implements extra bits for avoiding fidelity loose and extra noise floor when playing at low volumes. I don’t know so much about if is that possible (oversampling to 32/192 by the system according to WiiM).
