Mod note: moved this from another thread as it could use some expert review…
Unfortunately, I couldn't find any information from WIIM itself about the “Volume Limit” setting. The manual simply states that this setting exists. If anyone here can provide more first-hand information from WIIM, that would be greatly appreciated.
Regarding my Pro Plus, to avoid any misunderstanding, the device does not appear to be faulty. I will know for sure in two or three weeks because I am meeting up with friends in the country, two of whom have the same Pro Plus. We will compare it directly with my device in every respect.
We can also rule out analog clipping in the various preamps.
I have now also connected my EAR 864, which can also handle high input voltages, and the picture is the same. Furthermore, analog clipping sounds completely different to my ears.
Everything that follows refers to the use of the analog RCA outputs with the internal DAC.
What I'm experiencing is that the Pro Plus simply doesn't sound good with the parameters set to normal – EQ off, room correction off, analog output 2V (I also tried it with 1V output and it sounds equally unsatisfactory), pre gain neutral, volume limit 100%, volume in the range between 60% and 90%.
When I heard the Pro Plus for the first time, I thought it had a very nice, pleasing and appealing sound. But it was somehow very strangely compressed, with a certain sharpness and a loss of spatiality. My ears tired quickly and I was on the verge of returning the Pro Plus for another brand.
On the last evening before returning it, I played around with the volume limiter. I hadn't read anything about this setting and its effect yet. When I reduced the voltage range by 5% = -3 dB, all these faulty sounds disappeared. Incidentally, not many people seem to understand how this volume limiter works. At least I didn't find any forum members who obviously had any knowledge of it (at the time). I will continue to post under the link to the other forum.
If I understand correctly, the volume limiter reduces the digital signal after the PEQs etc. but before the analog filters. So exactly at the point in the circuit where
@totti1965 talks about “inter sampling over.” And I think he's hit the nail on the head. It's great that I can set the Pro Plus to make me very happy. But it would be disastrous if 99% of all users never thought of using the volume limit sensibly, especially since Wiim doesn't say anything about it. Users can understand that you set a limit if, for example, you exceed the headroom with a 9 dB bass boost in the EQ. But hardly anyone will ever know that the volume limiter is indispensable for a really good sound, even when the EQ is turned off. Once again, without volume limitation, the Pro Plus doesn't sound damaged, but only with volume limitation does it sound exceptionally good.
It concerns the problem described here:
And here dBFS is described very well; without this, it's impossible to understand what it's all about.
en.wikipedia.org
Here is finally the link to the other forum that I promised above. There is a poster there who explains the issue really well. His name is “onlyoneme.”
If volume set on fixed, will volume limit has no effect?
forum.wiimhome.com
It's only six pages... but they're really worth reading. All the nonsense there talking about bit perfect isn't important to me, though; it just shows that some people don't understand what this thread is about. Incidentally, the video explains this problem very well too.
