antcollinet
Can you give some examples - I've never knowingly heard the effect of an ISO - I would quite like to if I have a CD with some on.Intersample overs are pretty common in my experience.
And a bunch of associated inter modulation distortion in your speakers (and other places)It does not bring anything terrible except inaudible ultrasonic garbage.
Greg, look at this site. https://min.sjtu.edu.cn/files/wavelet/3-wavelet bases.pdf in particular the part about "regularity conditions". If you're going to 'stack' filters, i.e. for stepwise upsample, etc, which is rather an obviously necessary thing, you need at least ONE zero/set of zeros at the original (upsampling) or final (downsampling) fs/2 to meet the regularity requirements.The wider transition band also benefits the impulse response characteristics of the filter.
No I haven't. To wit, I give a pass to DACs that have their maximum attenuation at 24 kHz instead of 22.05 kHz at 44.1 kHz sampling.However, Amir keeps talking about the importance of strictly obeying the bandlimiting requirement of sampling theorem and seemingly asserting that no real ADC would violate this.
@Kal Rubinson uses their gear and I will probably be the next to follow as they are really nice and flexible.Above graph is from the marketing material of an ADC/DAC company by the way (who is completely in DSD camp): https://www.merging.com/highlights/high-resolution
If they're using misleading material like the posted to sell their gear, I for one would avoid them on principle.@Kal Rubinson uses their gear and I will probably be the next to follow as they are really nice and flexible.
Merging is very highly regarded in pro community.
Can you please reupload?Whew. That's a toughie. If you have an unwrapped phase plot, first, you want to do 1st order linear regression on it, this removes the "pure delay" component.
Once you've done that, analyze it for rapid phase changes inside 1 ERB or so. That's what will bite you.
Many of you may have seen an old paper that said "one million degrees of phase shift is inaudible" (intraaurally). That particular amount of phase shift was almost pure delay. Ooops.
WeTransfer | Send Large Files Fast
The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.we.tl
listen to the two files. The amplitude spectra of the two are absolutely identical.
Now listen to the two. How they were made is in the .m file.
I see that in the context of wavelets, subband filter banks, etc. But for the case of a single antialiasing or reconstruction filter, does it still apply?If you're going to 'stack' filters, i.e. for stepwise upsample, etc, which is rather an obviously necessary thing, you need at least ONE zero/set of zeros at the original (upsampling) or final (downsampling) fs/2 to meet the regularity requirements.
As Amir said, its only about the visuals.If they're using misleading material like the posted to sell their gear, I for one would avoid them on principle.
BTW, here is a more complete explanation of regularity in this context: https://perso.telecom-paristech.fr/rioul/publis/199304blurioul.pdf
Merging's potential buyers are not expected to be consumer market, they are solely a pro company (even their protocol is pro, don't expect the usual connections, they operate in Dante environment)
For a while, they made a push into consumer market resulting in some amount of sales to high-end consumers. That has faded though from what I can tell.Merging is very highly regarded in pro community.
Alright, then I apologize for misrepresenting what you meant to say.No I haven't.
Any CD that hits full scale (which is a lot of them) probably has at least one intersample over. I've not tried to see if I can hear the effect, so I can't really say anything about audibility except that an intersample over should be more objectionable than similar "ordinary" clipping (analog or properly bandlimited digital) due to the aliasing that occurs. The way my main system is set up, intersample overs aren't really a problem anyway as I already have extra headroom for the digital crossover and room correction filters I use.Can you give some examples - I've never knowingly heard the effect of an ISO
If an antialiasing filter has its cutoff (half magnitude) at Fs/2, then it is theoretically possible to get an "illegal" impulse from it.
There are a number of examples posted in this thread here. I'll throw in one more that I just looked at: Bloom by Larkin Poe. Oversampling 16x with a sharp filter that reaches full stopband attenuation (>200dB) at Fs/2 reveals approx. 1400 overs for the whole album with the maximum peak being +0.53dBFS.
Indeed, the most obvious example is the sequence +1 +1 -1 -1 repeated. But it can be worse than that.Intersample overs can occur if the sample instants just happen to straddle the true peak in the analog signal. In addition, if any resampling is taking place in the digital domain, they can potentially occur because of overshoot in the resampling filter itself.
sample log said:[2025-07-05 13:44:42.240] WV_mch_peakmeter:: overload/clipping/peak level detected: PeakLevel=0.0dB; Total clips=68; @ F:\MUSIC\...
[2025-07-11 20:22:55.907] WV_mch_peakmeter:: overload/clipping/peak level detected: PeakLevel=0.3dB; Total clips=3; @ F:\MUSIC\...
[2025-07-13 16:19:21.683] WV_mch_peakmeter:: overload/clipping/peak level detected: PeakLevel=1.6dB; Total clips=84; @ F:\MUSIC\...
[2025-07-13 16:26:41.113] WV_mch_peakmeter:: overload/clipping/peak level detected: PeakLevel=0.5dB; Total clips=7; @ F:\MUSIC\...
[2025-07-20 16:10:15.859] WV_mch_peakmeter:: overload/clipping/peak level detected: PeakLevel=1.5dB; Total clips=964; @ Z:\...
Is that due to aliasing from overflow, or something else? (I know very little about lossy codecs beyond a vague idea of what they do)And when they are put through a perceptual encoder, it's a mess of epic proportions.
Indeed. A simple example is to apply an IIR allpass filter. No change in frequency response, but the modified phase response very often results in clipping with commercial recordings.digital filter processing can also cause overload
Lossy codecs I've tested pretty commonly produce samples above full scale with commercial recordings when decoding to float. One such example is this track (seemingly a favorite of Gene from Audioholics). The Opus audio, direct from YouTube, produces 146 samples (out of ~21M) above full scale with the highest peak at +1.37dBFS.
