Thanks very much for your response. I was thinking that the problem at pi was theoretically solved by the signal being of infinite length. If it isn't, is "ideal" downsampling via the Whittaker-Shannon interpolation formula as explained here mathematically invalid?The answer to that question is "it's indeterminant" at pi.
If you start with a continuous-time Dirac delta function, bandlimit it with a normalized sinc function, then sample it at all integer times, do you not then have the signal in question? The central peak is the non-zero sample; all other samples are at the zero crossings.which means you can never MAKE that signal from a continuous system that's being sampled
