Keith_W
Can you expand on what you specifically mean here? Time alignment between the drivers needs to be repeated? Can you describe exactly what filters you are applying?
LR4 HPF @ 50Hz, and LR4 LPF @ 50Hz.
With reference to the above diagram, red is the LPF, green is the HPF, and brown is the sum of LPF + HPF. I have placed a marker at 50Hz.
At 50Hz, the phase of the LPF is -179 deg. The HPF is -158 deg. I have to align both to the tweeter, which itself is rotating phase. To avoid confusing matters, let's say it is at 0 degrees.
Phase = time. We can calculate the time discrepancy from the phase angle with t = theta / (360*f). So the LPF is 179/(360*50) = 9.94ms, and the HPF is 8.78ms.
In reality the drivers themselves introduce additional phase rotation, and as mentioned the tweeter probably isn't at 0 degrees. This is why the time alignment procedure needs to be repeated. Regardless, I always repeat the time alignment procedure whenever I make a change to the XO if there are phase changes (there are always phase changes). It's just good practice.
