KSTR
And yes, this track IS dangerous. Use with caution. Main energy is at 60Hz, one cycle basically. I notice almost no effect of polarity inversion, btw.
If you want a long sales book mainly on PS Audio and Paul (who is no audio engineer either), buck up; otherwise, save your hard-earned money.I am no audio engineer, but does this review mean that we should immediately confine the £60 Audiophile Guide by Paul McGowan to the bin?
I’m particularly grumpy today. So that has a bit to do with it.
You have convinced me not to try these tests. I want to continue to listen to the music and not the system! Some while ago I decided not to train my listening for the same reason.Well, once you fully aware that there can be a systematic effect (and often is), you will also note it in normal recreational listening, assumed you have access to a polarity flip switch (many DACs have, SW players as well, or just use a plugin).
Pushing 70 and still far too much music to try to spend long on listening to the kit. I enjoy understanding the audio kit and phycoacoustics but risking my enjoyment no thanks.We all go through stages where you listen to the music, the system, the system, the system and then back to the music for a while.
It all boils down to whether the music is the reason for high fidelity gear existing in the first place, or the gear itself is why we have high fidelity equipment at all.
Chicken and egg stuff.
Energy spectrum of the whole recording:Just like a loudspeaker's impulse response, you do not see the low frequency components unless you FFT a longer window, there is significant output to and below 10Hz. Like i said too, often there is a difference in the sound but not clear one is "better" than the other.
3D... really depends on the microphone being used... And if a microphone was used. If all the instruments are just being recorded in mono and piped into a mixing board, probably not, apart from whatever the producer put there.If we assume that stereo image is 3D and contains distance information, then distance information may be distorted due to different phase at different frequencies.
Moved how? Pure tones are going to sound as thought they're coming out of the driver tasked with the bandwidth that tone occupies, apart from tones where they have considerable overlap.It may be difficult or impossible to hear at the high frequencies where amp roll-off is occurring, but when I was designing cross-over filters (long time ago, though), I was using the test signal of a sweep frequency fixed point source that I recorded myself. If the sound source moved (and it often did) I was assuming speaker had a problem, as point was relatively static when played back through the single driver speakers.
Without any scientific proof, I was assuming this was caused by phase shift in the filter. Or is it all wrong?
Isn't there? Null-tests, for example, will show any deviation between any two signals.Is phase shift part of the reason why there isn't currently a way of testing audio gear with arbitrary signals?
Right, you can null test amps, like that famous story about Bob Carver... But I would expect two signals with different phase shifts to not completely null out.Isn't there? Null-tests, for example, will show any deviation between any two signals.
Yes, but that doesn't stop there from being a method of testing gear with arbitrary signals. Anything that doesn't null is a difference, by definition. That was the only part of your post I was replying to.Right, you can null test amps, like that famous story about Bob Carver... But I would expect two signals with different phase shifts to not completely null out.
Ah I see, I meant in the context of a device akin to an AP analyzer, if you could play an arbitrary signal (music, for example) through one and get a THD/IMD number out of it.Yes, but that doesn't stop there from being a method of testing gear with arbitrary signals. Anything that doesn't null is a difference, by definition. That was the only part of your post I was replying to.
Whether the difference is audible, and if so how much - those are separate questions.
You can place mono source signals aynwhere into the 3D space with a number of means, one well known is called Q-Sound.3D... really depends on the microphone being used... And if a microphone was used. If all the instruments are just being recorded in mono and piped into a mixing board, probably not, apart from whatever the producer put there.
I've been labouring reading on the phone the last few days, and just back with the laptop.
Not really. Digging my heals in and misremembering old papers. I felt sure I remembered the conclusions of the Lipshitz paper properly, but I didn't.That totally explains it.
