So, it’s a matter of redesigning the unit rather than just tweaking a single detail like the op-amps. Someone with the right knowledge and expertise could tackle a project like that. But how many hi-fi enthusiasts actually possess that? I’m not talking about the kind of knowledge gained from reading a few online threads, but rather solid expertise and experience—like being a trained electrical engineer, and so on.Exactly! Comparing op-amps without modifying the circuit versus modifying the circuit to match them are two completely different topics. Heck, even keeping the same topology and gain, but changing the resistor values, is a whole other story in itself.
(I don’t have that myself; I’m simply noting what is realistically required.)
Here’s a tip for beginners—or anyone without extensive technical knowledge—to try out: a
battery-powered DIY preamp. It’s the simplest design imaginable: an op-amp, a few resistors, and some capacitors. The most expensive part is probably a decent-quality volume potentiometer (if you want one). Add an enclosure and some input/output jacks, and you’re all set. It’s mostly just a fun project to experiment with.
In the video: the construction project from start to finish, including the schematic, and finally, measurements of its performance (which is good):
Tip: buy rechargeable batteries for it—for example, two of these:
https://www.amazon.com/9v-rechargeable-batteries/s?k=9v+rechargeable+batteries&page=3
