Layout.OPA's origin?
Put in an adapter with nice long pins I guess.
Schematic?
Schematic?
OPA's origin?
Schematic?
Layout.
Digikey= original, check.Digikey. No adapters.
Many pros avoid LM4562 like the plague because of their tendency to produce the dreaded popcorn noise. I have personally seen failure rates of more than 50% on some batches (and the company I worked for lost a lot of money from that). That was 15 years ago and I never touched an LM4562 ever since.I was comparing the 5532 to the LME4562 and just when I thought I had a "tell," at least one of the 4562 units started popcorning.
And I thought LME49720 was fragile, thanks for the info.Many pros avoid LM4562 like the plague because of their tendency to produce the dreaded popcorn noise. I have personally seen failure rates of more than 50% on some batches (and the company I worked for lost a lot of money from that). That was 15 years ago and I never touched an LM4562 ever since.
Try LME49860. It's 49720 with finer/smoother treble.LME49720 and LM4562 is the exact same chip (the original LM4562 name was only kept to kept purchase agents happy ;-)
Description
The LME49720 device is part of the ultra-low
distortion, low noise, high slew rate operational
amplifier series optimized and fully specified for high
performance, high fidelity applications. Combining
advanced leading-edge process technology with
state-of-the-art circuit design, the LME49720 audio
operational amplifiers deliver superior audio signal
amplification for outstanding audio performance. The
LME49720 combines extremely low voltage noise
density (2.7nV/√Hz) with vanishingly low THD+N
(0.00003%) to easily satisfy the most demanding
audio applications.
DESCRIPTION
The LME49860 is part of the ultra-low
state-of-the-art circuit design, the LME49860 audio
LME49860 combines extremely low voltage noise
audio applications.
Again, it is very very likely the exact same chip as 49720/4562, even TI support says so. The 49860 simply rated with a higher absolute max supply voltage, but all specifications are really 100% identical to the most minute detail.Try LME49860. It's 49720 with finer/smoother treble.
Pure gold!Again, it is very very likely the exact same chip as 49720/4562, even TI support says so. The 49860 simply rated with a higher absolute max supply voltage, but all specifications are really 100% identical to the most minute detail.
We have to thank TI/NS for these same chips with different names because they created the perfect test scenario to show false positives ;-)
Because that’s the price for one of them. If you buy in bulk, you get much much better prices elsewhere:And as we're there and the game is starting to get funny, how come Audiophonics have TI LM4562NA/NOPB for 3.5 euro while Mouser's price is 7.5 euro???
I know that, but even so it's 4.4 euro/piece for 2500 pieces at Mouser.Because that’s the price for one of them. If you buy in bulk, you get much much better prices elsewhere:
This is quite normal for these kinds of components. Generally one does not buy in bulk from Mouser either if one’s values a competitive price.I know that, but even so it's 4.4 euro/piece for 2500 pieces at Mouser.
Something does not add up.
I am extremely suspicious to opamp parts offered by Audiophonics. The prices do not make sense and the photos (OPA627) are suspicious again.And as we're there and the game is starting to get funny, how come Audiophonics have TI LM4562NA/NOPB for 3.5 euro while Mouser's price is 7.5 euro???
I'm on the verge to buy a bunch and measure them, just out of curiosity.I am extremely suspicious to opamp parts offered by Audiophonics. The prices do not make sense and the photos (OPA627) are suspicious again.
