Censorship seldom leads to anything good. Have you listened to the files he posted, or is this an example of "contempt before examination?"Please don't give clicks to that shill
Apparently you haven't read this entire thread...Censorship seldom leads to anything good. Have you listened to the files he posted, or is this an example of "contempt before examination?"
BTW- IMHO, I can order customized Converse sneakers. Why don't the manufacturers of this so-called TPA3255 Class D amp put a choice on the op-amp before placing order? For example - customize it with: 1. "meh" chip, 2. good chip, 3. better chip, 4. best chip, and 5—you can't beat this cheap I meant chip. . Dell e-commerce site started this way for selling home PCs, I'm wondering why Aiyima and Fosi Audio (and the latecomer Douk) can't do it? Why do I need to DIY it myself? If I want a certain signature of music where lots of reviews and recommendations are already done, why can't I pre-ordered it with the chip I think will work to my taste and just try them into my speakers?
That way I don't potentially destroy (or scratch it up) enclosures and the main board and most importantly. Also, I would like to save my very-very precious time!
The fact that the captured files have different levels is not an opinion. It is a fact:So, through opinion and innuendo it has been proven he's scamming with the files he posted. I see.
very little if at all
He posts some example with audible differences. I suspect these are also measurable. Danny gets some things wrong but also he gets some things right.
No innuendo here - failing to match levels reveals ignorance or intentional avoidance of the most basic controls. Any self-appointed audio expert so staggeringly ignorant is making content for entertainment purposes only.So, through opinion and innuendo it has been proven he's scamming with the files he posted. I see.
You flat-eartherPlease don't give clicks to that shill
Huh?You flat-eartherLOL
Danny Richie calls folks who don't buy into his b00|$hit "flat earthers."Huh?
Ohh. Well that says A LOT about himDanny Richie calls folks who don't buy into his b00|$hit "flat earthers."
I am quite sure this is the case.Not so innocent explanation is that they played with each captured files until their favorite sounded "better" and post it
He gets most things wrong and is manipulative with bad intentions. Yesterday, while browsing through the comments on his video, I noticed that most of the critical comments had been removed. Just days earlier, the majority were critical, but now the balance has shifted completely. For example, I couldn’t find this comment yesterday:
www.audiosciencereview.com
You might be surprised. We made and used PA mixing consoles in the early 70s that used LM747s (almost the same as the LM709, but duals like the LM5532). With a 0.5 V/uS slew rate you might think the sound was compromised, but not much. The musical energy in the higher frequencies is generally too low to challenge that slew rate. Recordings made directly off the console sounded good, especially after the introduction of electret microphones.So, you're saying that opamps don't matter, so if my audio gear had IC709 opamps in it, it would sound just as good as if it had Sparkos SS3602's? Hmmm. I'm not so sure about that.
It was SE5532, NE5532 in fact, not LM. Signetics company. But I agree with your post. Only that 741 or 709 could have been used only in case of low level stages (1V). Some designs used it to get >8V driving stages and then the slew rate limit was audible.You have to take your hat off to the inventors of the LM5532 at National Semiconductor
I would spend hours going through it. They seemed like gift from heaven! Free schematics for all sorts of things.I still have an original copy of the National Semiconductor applications book, a huge bible for DIYers building just about anything in lower-frequency analog applications
I have a test rig to test dual operational amplifiers, at low gain and high gain.
If there are readers interested here, I can make quite detailed comparison of LME49720 (LM4562), NE5532, OPA2134 and LM1458 in a new separate thread. THDlevel, THDfrequency, CCIF IMD, DIM24 and DIM48, square responses. Just let me know.
