DualTriode
- Joined
- Oct 24, 2019
- Messages
- 997
- Likes
- 665
So, turning up the volume above 5 watts does make sense.
So @Ant and All, The 1 kHz FFT plot posted by @amirm does show different harmonics. The stock Op-Amp shows higher High Order Distortions. The higher order HD's that show up in in the AP Rub and Buzz plots. Can you hear driver Rub and Buzz?
The first claim was that the measurements were the same, we can see that they are not. The no difference claim is an exaggeration. True
Then came the claim that you can not hear the difference.
The 1 kHz FFT plot posted by @amirm does show different harmonics. That 1 kHz FFT plot only shows the 1 kHz harmonics. Take the next step and run a multi-tone FFT plot. Closer to the multi-tone environment of playing "real music", all the harmonics show up including the Higher Order harmonics. Quite the cacophony. Will any of this show up in the SINAD number? Not really, the value of SINAD is limited to a single measurement at 1 kHz.
Take a look at the 6:45 mark in the original A5 amplifier review. Do you think that you can hear the higher High Order Distortions of the 1 kHz tone, likely not. The multi-tone Plot shows a pile of harmonic hash between/among the test tones. Do you think that you can hear that? If you can, it will not be identified as a barley audible 5th harmonic of the 1kHz test tone.
Douk Audio A5 Stereo Budget Amplifier Review [Video]
Video review of the Douk Audio A5 amplifier is out including a bit about listening tests that was not in the text review: https://www.audiosciencereview.com/forum/index.php?threads/douk-a5-budget-stereo-amplifier-review.61410/ Please subscribe to the channel. It is not monetized but like to...
