LOL, we're the flat earthers! I don't even know what to say to that.
Just yet another example of his backwards understanding of science.
Based on the analysis of the recordings having differences that no op amp swap can create there are two possibilities.Just yet another example of his backwards understanding of science.![]()
During the live, he was asked a question re: Amir's review of the XLS Encore, and claimed that you tried to build it in a way that it would measure as poorly as possible.Just yet another example of his backwards understanding of science.![]()
He mentioned that you purposely didn't use No Rez and some other insulation that he recommends for the build, and that you didn't round off the corners to prevent diffraction. But that despite your best efforts to sabotage his product, that it measured great anyway so Amir had to begrudgingly give it a recommendation.![]()
www.audiosciencereview.com
Opamps are specifically made to use feedback to control the transfer function. They will not function (as a practical matter) without it. So things like frequency response and gain are controlled by the external components, not by the opamp itself. Although things like open loop gain can vary from one device to another, it's invariably high enough to make no difference.Hi Amir,
I have a question about your testing method. Does feedback cause the op amps to harmonise their output, would the feedback actually suppress the differences, and therefore if both channel Op amps were changed the feedback would be different and the results also different. I ask purely out of a lack of knowledge on my part. I’m sure that your original results are true.
The left and right channels are independent.Hi Amir,
Yep, this.Opamps are specifically made to use feedback to control the transfer function. They will not function (as a practical matter) without it. So things like frequency response and gain are controlled by the external components, not by the opamp itself. Although things like open loop gain can vary from one device to another, it's invariably high enough to make no difference.
And this.The left and right channels are independent.
The left and right channels are independent, no mixing, no feedback no nothing.Ahh ok thanks. So there is no feedback used to balance the different channels.
Basically. If each channel has a feedback resistance ratio of 100:1 (say), the gain will be set by that ratio (about 40dB in this case). Channel to channel, the only gain variation will be because of resistor tolerances, NOT the opamp.Ahh ok thanks. So there is no feedback used to balance the different channels.
Let's put to one side the fact that beliefs are like opinions: Everyone has one, and they are nearly always smelly.I have come to believe that both THD+N and SINAD are near worthless as indicators of perceived audio quality.
In this context, OP-Amp rolling, THD+N and SINAD are near worthless indicators of the perceived audio quality between op-amps.
Also scientific, measurements of PEAQ may be discriminating where THD+N and SINAD are not. Evidence of masking of low order harmonics fills the AES Library. High order harmonics are much more annoying even at seemingly low values. This is the stuff of rub and buzz and PEAQ measurements.
amirm you may need to upgrade you APx555 instrument.
Thanks DT
It is not surprising: it actually happens that op-amps bearing the same designation but coming from different manufacturers have slightly different specs or produce slightly different measurable end results in some application.I'll tell you something maybe a little surprising. There are differences between even the same model of op-amps coming from different brands. I have a circuit here that is stable without feedback bypass capacitors when using Rohm brand 4580 opamps, but is unstable and requires feedback bypassing by 100pF with Diodes Inc 4580 opamps.
This data was presented:Evidence of masking of low order harmonics fills the AES Library.
You are missing the point. This test doesn't rely on a qualitative assessment of different levels, or components of THD. The point here is that the harmonic distortion DOES NOT CHANGE. So there can similarly be no perception of a change in audio quality. Or at least no perception that is resulting from the sound reaching the listeners eardrums.![]()
Are you really suggesting the $30K AP is not up to task?amirm you may need to upgrade you APx555 instrument.
JSmith
PEAQ is used to evaluate an audio codec vs the original signal, what does that have to do with testing an amplifier?The Apx555 is what is on my bench.
The SINAD application in the APx500 software can use some help. As previously stated, a APx555 audio analyzer with a GRAS microphone is not a human ear. Upgrade as in get the add ons.
Audio Precision also has PEAQ software application(s) available.
PEAQ testing also shows in the APx500 software speaker Rub and Buzz testing applications.
