solderdude
What's your Y-axis in this plot?
It is noted above the axis. dB (SPL of course)
I read there is a dBA versus dB SPL war
I read there is a loudness war.
Well my most expensive cable is a pair of Sommer Eclipse XLR. As for my setup, I use DAC/amp (2-in-1). I basically don't buy cables. I don't trust none professional brands.
So my issue on this is purely the methodology check. I don't really care if someone wants to buy a $1000 usd cable. I won't talk them out of it. If money can buy happiness, why destroy it.
The fact is, I have never said Ethan is right or wrong about cable being the same; or my opinion on this matter.
So I am getting on oscilloscope today. Before I get back with my test results, here is a discussion on Ethan's test procedure:
Ethan's assumption (that he was to support with his experiment) was that, cable passed signal the same. Based on that, if you had exactly the same cables hooked up, any difference would be due to channel imbalance of null tester, correct?
So to calibrate that, We should use the same cables, and null out signal difference once before doing cable swap, correct?
Now experiment start, we swap cables. Question 3 , is it justifiable to touch any knobs that could affect channel balance once null tester was calibrated?
In Ethan's video, he got new cable on, turn the knobs, null achieved. [Calibration] --> Then he changed cable, null broke. [ Doesn't that already prove cable newly installed is different from previous one?] --> He turned knobs again, null achieved [re-calibration] --> He said cables were the same [Questionable. Previous step only proves he can re-calibrate the difference. His instrument can null out signal difference smaller than 2.2mV perfectly].
Another question is, how does knobs affect the difference (reserved for another discussion).
I see what he is trying to prove,. He doesn't mean cables pass sound the same. He tried to prove that once you matched dB/SPL, difference is not audible. This part I am not to going to argue with.
However I don't think it translate well into in real world practice, as high quality hardware is required for this. For example, if you look at his audioexpress writing, his volume pot is a stepped attenuator, which is miles better than anything commonly used in consumer electronics. I won't be surprised matching dB/SPL with average consumer electronics can sometimes introduce some audible issues, especially in headphone systems. I currently already swapped out a few inferior volume pots in my gears, however I cannot used a stepped one in my gear.
Consumer headphone amps that have a stepped attentuator or something similar... cost much more than a $700 USD cable... Yes I mean that benchmark one.
I got multiple denials on digital approach on this. Digital gears are somewhat completed in nature.
Consumer headphone amps that have a high quality stepped attentuator or something similar... cost much more than a $700 USD cable... Yes I mean that benchmark one. That's a hefty priced equipment to get so one can enjoy cheap cables...
I don't know why I got bashed when I said I can approach it digitally. So I cannot answer your question.
You ignored a few other things. At least, by far I haven't get a 9mm pot that has exactly 10K or same R in two channels. I didn't bother testing how well it tracked. I am bothered since I have balanced amp.
Please also quote pkane on this one. I think if he has a good ADC, which is probably going to achieve -110dB noise floor as well.
They all add distortion. But ADC gives ability to work with data afterwards.
So you are assuming I know who you know? Or I know Paul is pkane?
Can confirm. Just swapped original hd600 cable to factory replacement hd650 one and the sound is different in a bad way. Its like a pale imitation of what hd600 sounds like lol cant believe its that much worse. Shame cuz hd650 cable seems way better quality. Guess ill have to buy hd600 one.Maybe difference between HD600 and HD650 cables. These two are commonly considered different.
Best i can describe it is that it doesnst move the driver in the same way. So the back round stuff and the highs are muted noticeably. Bass is stronger though oddly. Shouldve went with the right cable thought i could save 10 bucks lol. Damnit.
Provided the new cable is working as it should, no clue. Probably should ask sennheiser engineers why they bundle hd600 cable with hd600 and hd650 with hd650 hmm?You need to get a hearing test
What would make them sound any different, providing one is not broken ?
What are the electrical differences between these cables ?
You made the claim, I already measured those cables so I know.
There is no cable (other than the ones I make) that have any filter action so what you describe is physically impossible given the test results I have.
Here is some more discussion on headphone cables
and more
What i heard went in line with what other people posted online a decade ago so. I can also do a blind test but its pointless.
Ill do it once the hd600 cable arrives. Youll see AAAAAAAAAAAHAHAHAHAAAAAAAAAAAAAAAA..........It's Make-Believe Time!
