- Joined
- Mar 21, 2019
- Messages
- 149
- Likes
- 273
Yes, since we all have one of them alongside our other supercars in our garage, we can off course all relate to that...
It could be slightly improved with additional FIR filters for speaker crossover phase shifts but I use a simulator (don't have MiniDSP) and Flex DL version didn't seem to have FIR filter slots unlike the Flex. It's a minor improvement that lifts the center stage a little higher.@OCA after extensive listening: your PEQ and timing does very well. I compared it with different time allign methods, yours easily wins.
I checked the polarity of the speakers and amp and they are correct.
So now I only have to decide if I'll buy an extra sub or not.
I can easily switch to the regular Flex version if that helps.It could be slightly improved with additional FIR filters for speaker crossover phase shifts but I use a simulator (don't have MiniDSP) and Flex DL version didn't seem to have FIR filter slots unlike the Flex. It's a minor improvement that lifts the center stage a little higher.
Cool then. I'd place them symmetrically near the left and right speakers. Think of it as having floorstanders with large yet mobile woofers.I can easily switch to the regular Flex version if that helps.
If I were to buy a second sub, would you advice under the left speaker or behind the couch (as the custom sub is)?
They're the same.And is it easy to make Flex filters for the current measurements?
I'll contact you when the new sub and cabinets arrives. Could take a while and I'll send a DM
And digital crossoversCool then. I'd place them symmetrically near the left and right speakers. Think of it as having floorstanders with large yet mobile woofers.
Simply connect both subs to the WiiM's Sub out using an RCA splitter:I'm hooking it up on my Wiim Pro amp for ease or use. Does anyone know if daisy chaining the LFE signal works (without delay) on the SVS 2000 Pro?
Can't find it specifically in the manual.
You need less cable length and there's no downside.Is that better than daisy chaining?
Okey, just to continue this journey.
When listening, but measuring, the following crossovers sound nice. The standard Wiim sub out XO is LR 24 dB/oct I think.
1. 80 Hz (24 db/oct)
2. 60 Hz (24 db/oct)
3. 60 Hz without rolloff at mains (use natural rolloff) and subwoofer at 24 db/oct.
Any theoretical ideal choices?
Only with multiple listening positions.multiple subs allow you to get a better frequency response
