Keith_W
any thoughts?
You didn't show any measurements, so there is nothing to say?
5.23ms delay is not unusual for subwoofers. In fact it's pretty normal.
any thoughts?
Coming weekend I'll thoroughly test various xo's. But I'm still wondering about that 5.23 ms delay on the mains.
any thoughts?
Thanks, I thought it was lot since the speakers are close to the sub.For your reference, my KH310 almost right up to the front wall with one third party sub in the middle yielded 6ms mains delay (determined via REW step response sighted/manual estimation). My XO is 100Hz.
Yours is probably correct.
I'll post some measurements soon.
Is the XO then the best place to set your delay time? It seems then that all delay are wrong so have to choosing an optimal value.The delay is also caused by the inherent group delay of subwoofers. A lot of beginners think that subwoofers have constant group delay - i.e. that the "5.23 ms" delay applies to all bass frequencies. If 50Hz is 5.23ms delayed, then 20Hz must also be 5.23ms delayed. This is not true. Let me show you something.
Take an actual subwoofer measurement (blue) and create a bandpass crossover (green) to match it. Here, I have a 5th order Butterworth XO with corner frequencies of 20Hz and 80Hz. You can see that its roll-off almost matches the subwoofer. So this will be our simulation sub.
And this is the group delay of the simulation vs. the real sub. The vertical scale is in milliseconds. You can see that the minimum-phase nature of the simulation is already causing the group delay to rise at low frequencies, never mind all the physical problems of subwoofers (driver inertia, ports, etc) that contribute to group delay.
Even on LFE mode with no processing whatsoever? Interesting!
I dunno about all modern subwoofers, but SVS certainly relies heavily on DSP for all their subwoofers AFAIK. There will certainly be an additional delay due to DSP regardless of whether or not any additional processing is enabled via the app.The tuning / crossover design / high pass / what have you of the subwoofer is very likely implemented in the digital domain via DSP, so there really is no such a thing as "no processing" in a modern subwoofer or active speaker.
5mSec at 20 Hz is a 36° phase shift; not really audibly apparent. (1/20Hz -> 50mSec per cycle; 5mS/50mS=36°/360°)Why does 5.23ms sound like a lot to you?
What you do is:Would you be able to link me to that post? I have to admit it's not clear to me what you are referring to.
