Hi,
I have two Sonus Faber venere 2.5, five speakers of Klipsh Quintet II and Klipsh sub.
The speakers are connected as 7.1 ( with two high front klipsh speakers).
I am looking to buy new Receiver that will be suitable to my needs and will push effectively the sonus faber. In addition, I want to replace the center speaker.
We are using the system mainly for Home theather, TV and music shows. Small portion of the use is for hearing music.
I saw good reviews about the Denon 4700 but not sure if it will be able to push effectively the 6 ohm sonus faber 2.5. In addition, i received a proposal to buy Arcam Av10 or Arcam Av20 which are much expensive.
I will appricate your response on which Receiver is better to buy
Thanks
https://www.sonusfaber.com/en/products/venere-25/
https://www.klipsch.com/products/quintet-ii-home-theater-system#post-product-summary
https://www.klipsch.com/products/sub-10-subwoofer
Thanks
