Do we want this specific reflection, at this delay, with this spectrum, from this speaker directivity, at this listening distance, for this playback goal? I think I can answer this in many contradictory ways
I think this is a misunderstanding.So the reflective panels actually added MORE later-arriving reflection energy than early-arriving reflection energy!
In the caption it is talked about the “temporary walls used to hang the variable acoustic treatment“ not about the specular reflecting panels themselves. In my view the information about “primary“, “secondary“ and “tertiary“ energy is about the change of the room from the experimental design (before applying the different wall treatments).
Assuming that the McGill room is shown and not the second mixing room, these walls are placed differently in the photo compared to the room plan. The plan would not make sense for investigating early lateral reflections as the walls would (partially) block these in the first place.
From the geometry a delay of 8ms is too long for the first reflections from these walls.
I drew the reflection paths for this geometry and the delay of the first reflections off these walls (the way it is shown in the photo) would be ≈4.6ms.
From my understanding these are “four-foot by four-foot (approximately 1.22 m by 1.22 m) area of false side wall“ and are used to hang “three different acoustical treatments mounted on modular panels (Fig. 2).“ [the blue things]So are those "temporary walls" just curtains to conceal whatever the actual wall treatment is?
Again, I think there is a reason for the use of the term “primary energy“ instead of first reflection.And that would also explain the 8 milliseconds arrival time for the first lateral reflection energy.
So there is an increase of “primary energy“ around 8ms from the frame arrangement, but the lateral first reflection from the false walls has a delay of 4.6ms (if not absorbed or deflected).
No...
In professional recording and mix control rooms with a large budget there will be still be reflections from the equipment, monitors, and glass surfaces such as windows between studios.Another interesting study is "Preferences of Critical Listening Environments Among Sound Engineers - SAKARI TERVO, , PERTTU LAUKKANEN, TAPIO LOKKI, JUKKA P ATYNEN - Department of Media Technology, Aalto University School of Science, FI-00076 Aalto - 2014". This study acknowledges the findings of the study mentioned by the OP and the work done by F. Toole, but it tries to get a better understanding of which control room acoustics sound engineers prefer.
A few quotes relevant to this thread:
The study confirms that just like audiophiles, also sound engineers can have preferences. It's the reason for 80's LEDE, RFZ and modern “non-environment” control room designs. (Note 'control room', not suggesting that this is what you need to do at home).
- "LEF (lateral energy fraction) correlates negatively at moderate levels (p<0.05) at high frequencies (1kHz and 2kHz octave bands). That is, the mixing engineers prefer that there is no energy from the sides besides the direct sound from the loudspeakers".
- "The correlations in Table 5 suggest that sound energy from sidewall reflections at high frequencies should be avoided".
- "Mastering engineers prefer more reverberant environments in general than mixing engineers and clarity is less significant for them".
Side note: Regarding the frequency band related observations there's study "Lateral reflections are favorable in concert halls due to binaural loudness - Tapio Lokki, Jukka Pätynen - Aalto University - November 2011", where one of the core findings is that lateral reflections are perceived louder than frontal reflections due to the shape of the human head and ears:
- The outer ear, head and torso form a direction-dependent filter. It boosts high-mid frequencies (~2–5 kHz region) and attenuates others depending on the direction of arrival
- For lateral sound ≈90°, one ear receives stronger direct signal while the other is shadowed, which creates large interaural level differences (ILD) and interaural time differences (ITD)
...what is wrong with starting with what would be best practices in stereo preferred by most people?
If I want a more direct sound field I simply listen in nearfield, in midfield or far field I have a better idea of what the average user in their room would hear.
One needs both approaches in mixing and especially mastering.
For playback one can do whatever they like, but after spending a lot of time and energy on treating first reflection points, how are you going to *compare this to how it was before?
I can compare both experiences simply by listening in near and mid field, how do you know what you prefer?
I presume you are aware of how thick your absorbers need to be not the color the sound and all of this is done well.
The preferences of how many reflections and how loud one wants to hear the reflections also differs between music and voice as well as from genre to genre from what I remember.
However, most people prefer louder beneficial reflections and/or higher delays then a room can give us, also depending on the recording, which one can do by up mixing and adding more speakers in front of the listener but at a different angle.
One however does not want to hear echo's, which is impacted by both loudness and delay.
This will never happen with just the reflections in a small listening room.
But one has to start somewhere, and that is with what we know.
As for me personally, side wall first reflection points would be one of the the last places I'd treat for stereo and if I wanted to treat it I'd try diffusors first, as they are seen as beneficial reflections.
Again, we have to start somewhere, so I start with what is pretty well understood, get the basics right, which is a great designed speaker.
If one wants to add room treatment, do not start with the side wall first reflection points, see it as an optional choice, but after treating other parts of the room that have not been shown to be beneficial reflections in stereo.
I saw that too...and a giant head and quite large speakers as well.Amir, I'm not just trying to be a contrarian here. If you see a mistake in my analysis, PLEASE point it out!
See the diagram below, which is Figure 2 from the paper, but I've drawn in the first ipsilateral and first contralateral reflection paths. I tried to draw the angle of incidence equal to the angle of reflection, and hopefully got close enough:
Now here's the important part: The first ipsilateral reflection MISSES the listening position altogether! There are no early same-side-wall reflections in the McGill study! (Or at least not at wavelengths were the propagation can be approximated by rays.)
The first lateral reflection is the one off the opposite side wall, and it arrives about 8 milliseconds later than the direct sound, just as the caption says. Here is the caption:
"Fig. 2. Top view of the testing facility at McGill University, with the temporary walls used to hang the variable acoustic treatment (the solid black lines on either side of the listener). The spacing of the temporary walls promoted a slight increase in primary reflected energy circa 8 ms after the arrival of the direct sound and a marked increase in secondary and tertiary reflected energy arriving approximately 12 to 30 ms after the direct sound."
This is not at all similar to what normally happens in a home audio room. In a normal home audio room, there would be a strong same-side-wall reflection usually arriving earlier than 8 milliseconds after the direct sound. Instead, in the McGill room, in the "reflective" case, we get no early same-side-wall reflections; a "slight increase" in the opposite-side-wall reflections; and a "marked increase" in later-arriving reflected energy.
@amirm, do you think my analysis indicating differences between the McGill study's set-up and what normally happens in a home audio context is correct (or close enough)?
And if so, do you think these difference are of any significance?
Anyway, now that I've looked at the actual first sidewall reflection paths, the results of the McGill study are not surprising to me.
Hm, for me that is not better as information about panel placement at all, sorry.There's a follow-up study where they build on the design of this study: "Interaction between critical listening environment acoustics and listener reverberation preference - Brett Leonard*, Richard L. King and Grzegorz Sikora - June 2013". This paper has better images of the room and the location of the reflective panels:
Diffusion on side walls should be aiming the energy at the ears directly. A 2D diffuser will waste half the energy toward the ceiling and floor. So a 1D diffuser is what should be used there, and if there's a desire for increased spaciousness it needs to offer temporal diffusion/changing the phase.@Bjorn thanks for the interesting comment.
Can you clarify on this point...
Do you mean only that it is undesireable to diffuse vertically or absorb in a study where the subject is in-plane lateral reflections; or that in all practical listening cases it is also undesirable?
In the empty room they seem to already cancel early reflections (octagon shape + treatment).
So they added reflective panels to diverge some sound to create in some way some lateral late reflections. But with this geometry, these side panels placements and angles, the only sound reflected goes to the back, and maybe bounce back to the head. So they are back reflections then, not lateral. (?)
If the plan is correct (it looks quite precise) and the side panels are placed this far back then the first reflections from the walls (in the original room) are not altered by the panels at all (red dotted lines).
And the (first) reflections from the panels do not reach the listener. (blue dotted lines)
So what do you call the distant point at which reflections overwhelm direct arrivals from the loudspeaker in home hi-fi listening rooms?The LLD is much closer than the acoustic Critical Distance.
