solderdude
In the days of tubes and analog gear (vinyl, tape) vibrations were certainly an issue.
Most certainly when used on wooden floors (vinyl).
Today... tubes, vinyl, analog tapes, some tuners even are still equally susceptible to vibrations. This stuff is what audiophiles love. I can see those folks might benefit from using feet.
I can also see benefits of putting speakers on damping feet, if only for the neighbors.
Some components that one taps on could cause audible issues. Usually they are mechanical components like crystals (these are mechanical components but not all of them are created equal), relay contacts, switch contacts, volume controls and in a far lesser degree (ceramic) capacitors.
You would have to tap on it though, which means a lot of G's usually. And when you tap on components you are also tapping on the PCB creating movement to components around it too.
The thing in practice is that G-forces induced by music is usually very low and mainly very low frequency only.
And even when this happens the speakers are very likely playing very loud and there will be a ton of distortion anyway.
So yes, there can be measurable and even audible effects even on SS gear but in everyday use there won't be a real difference unless one of the mechanical components in it is (going) faulty.
To the OP question:
When those vibrations are caused by reproduced music that would have to be really loud in very close proximity. The speakers would be distorting a LOT more than any vibrations could be causing.
Non-issue but tapping on components inside an amp (or perhaps even on the chassis) could be audible when there is silence in the room.
When blasting music through speakers those sounds will be overpowering any small measurable effects that might occur.
All of this assuming the amp in question does not have any 'mechanical components' in there that are (getting) faulty.
To the OP question:
Do vibrations have an impact on solid-state amplifiers' sound quality?
The answer is: it might and it depends on how much vibration we are talking about.When those vibrations are caused by reproduced music that would have to be really loud in very close proximity. The speakers would be distorting a LOT more than any vibrations could be causing.
