amccausland
- Joined
- Feb 26, 2021
- Messages
- 8
- Likes
- 3
Here is tonight's video. It is a digest of previous reviews of a couple of USB filters:
Reviews referenced:
AudioQuest JitterBug USB Filter Review: AudioQuest JitterBug USB Filter Review | Audio Science Review (ASR) Forum
ifi micro iUSB3.0 USB Filter Review: ifi micro iUSB3.0 USB Filter Review | Audio Science Review (ASR) Forum
Not anything new for longtime members here but I thought was a good one for newer members and youtube viewers.
The icing on the Audioquest cake for me was the instruction in the manual and on the jitterbug box that tells us plugging in a second jitterbug "in parallel" with the first one will improve the sound further (among other incredible claims, such as plugging one into the USB cable connected to your hard drive on your NAS where your music is stored). In other words, you plug in the first into the USB port that your USB to DAC cable is in, then plug in another into an empty port. I'm not an expert, but is it not correct that the one plugged into the empty USB port would have no current even flowing through it? How would it make any difference at all? With that kind of snake oil salesmanship, how can I trust anything from Audioquest?
[By the way, I also tried the Audioquest Beetle, and it was a dud. The output was audibly noisy, and since the output level was so low I had to crank up my amplifier to almost max gain just to listen at normal levels (for me about 75 dBA peaks). With that gain it was easy to hear the noise which appeared to be coming from the USB connection, and which occured even with a different usb cable or when I plugged it into power with no audio signal in. As a comparison, I plugged my Scarlett 2i4 interface into the same USB port and the same amp input and the noise disappeared. Even at a reduced price of $65 on Amazon the beetle was not worth it.]
Thanks for your reviews! It is refreshing to get some real data-driven analysis on audio products.
