holbob
Personnaly, I don't see the benefit of video reviews.
I never look at them.
But that may be just me.
I have one pair of AudioQuest cables that I bought back in the '90s. They failed after less than 2 years and I had to resolder the connectors (idiotic solid-core wires with insufficient strain relief), so they've been gathering dust at the bottom of my cable box for a couple of decades now. The one criterion for cables that actually matters is that they shouldn't fall apart is you look at them too hard.Is there an audio snake oil wall of shame? Every time I see the AudioQuest name it's some bullshit.
Not all USB isolators are like that from the movie
A Filter with a with a high common mode impedance (at the Frequency causing the problems) can also solve real world problems.In the video there is no review about isolators but filters. These differ immensely from isolators which can actually solve real world problems.
If it ain't broke don't try to fix it!
No. and i'm not advocating for this (probably overpriced?) "audiophile" device(s).Do you SEE any 'high common mode' filters in there in the dog-teardown device.
In some special case with a badly implemented source, that happen to have Noise at just the right frequency for this LC filter on the 5V line.The 5V is just LC filtered and data has some small caps
This is what i meant and hope you don't take offense from it.
Digest? I though the dog had only chewed it a bit.Here is tonight's video. It is a digest of previous reviews of a couple of USB filters:
I agree with you.Correct, the manufacturers claim is they make an audible differences and suggests in all cases and the more the better.
These devices do nothing but change ones mindset so owners believe it sounds better (and will to most).
All snake-oil despite maybe in specific situations with poor designed dongles
Yes.Those that want the filter to do a little bit about HF common mode crap filtering can run the USB cable 3 to 5 times though a ferrite ring.
I know what your trying to say. and in practice this might be right.In your case wind the USB cable a couple of times (max. 5) through a ferrite and you can filter some common mode noise (mostly radiated) from that USB connection. It will absolutely not solve any ground loops.
In your case wind the USB cable a couple of times (max. 5) through a ferrite and you can filter some common mode noise (mostly radiated) from that USB connection. It will absolutely not solve any ground loops. It can't. A real common mode filter would filter both the ground and +5V on a ferrite ring with windings in opposite directions so the core does not saturate. There you have the difference between common mode filter (which often also sa caps that filter differential mode as well) and a simple ferrite.
That might be more of a theoretical/conceptual question:
would you agree that a usb isolator inside in a black box would look form the outside like a common mode filter with very high impedance at low frequency?
But it all depended on the the frequency(s) of the current(s) in side the ground loop.
If we are talking about Mains frequency's and harmonics. then your right!
The winding direction is the only thing that matters. it's the combination of winding direction and current direction that dictates the direction of resulting magnetic flux.
Bifilar
I'm talking about the cheap ones from ebay/amazon they come usually without audiophile marketingNo. people will think it makes USB sound better. They do not care about why. reviewers and the manufacturer say so and thus it must be true.
no no of cause it Can't never be assumed. but it would behave similarly.I can never assume what's in a box. I would either have to see the schematics or the PCB and what's on it.
Yes, differential mode will not be Filtered only common mode.Mains frequencies and harmonics will not be filtered and are differential mode so they will not be filtered
Computers for example have many amps flowing trough the Mainboard etc. therefore causing some small voltage dropRF components, caused by switching electronic equipment that are referenced to ground
yes. That's the difference between a ferrite with a cable running through it and a common mode filter where 2 signal wires are separated and go around the coil.
Are you sure it eliminates ground loop?JohnYang1997 thy do work but its the manufachteres job to implement them inside of the devices.
Thats why you don't need extra external filters. The signal is already filtered.
https://www.we-online.com/web/en/el...bcm/blog_detail-worldofelectronics_108744.php
What i mean it in an (functional) "equivalent circuit" https://en.wikipedia.org/wiki/Equivalent_circuit
https://en.wikipedia.org/wiki/Two-port_network
the drop is current dependent the current is CPU/GPU determined and ther load varies well within the Audible range.
So USB GND might not be exactly the same Potential as Mains/Earth ground but acually a view mV or µV higer depending on laod/current.
If you connect it to an other mains/earht ground referenced USB device there might be commen mode curren flowing because of the potential difference. (with DC-MHz)
But the one wire going trough it is not one Conductor. its actually 2 (or more) wires in one comment case.
Therefore it is effectively Bifilar
And since i explained and as the this article explains its effectively equivalent https://www.we-online.com/web/en/el...pbcm/blog_detail-worldofelectronics_63294.php
With the Bifilar method having Less Differential mode inductance which is undesirable because the "ideal" common mode choke having only common mode impeance and no Differential mode impedance.
Would you be interested to further discuss this topic in a dedicated thread?
It depends on the filter. and the ground loop.Are you sure it eliminates ground loop?
Yes, unfortunately culturally we have gravitated from online text to YouTube videos and podcasts for most things these days. That simple fact, for example, has killed off many non-specialized computer review websites who were not wise enough to expand into audiovisual content. I understand videos speak a thousand words or just say in one visual word things words never could properly convey, but I detest the current state of the medium. Most of these video "reviews" these days are just drones mindlessly regurgitating PR releases, ego-stroking and grandstanding, and only revealing the good while purposely concealing the bad. Because of that, I make it a point to only read articles when I research PC hardware, so AnandTech or bust for me. And I try to do the same with audio products when and where I can. Nonetheless, like you say, I think it is smart and even advisable to publish YouTube reviews because that is honestly the only way you can reach most people these days. Tyll Hertsens, who also on more of the objectivist side of the aisle in the world of audio, saw the value of it himself and he did the same at a point with InnerFidelity, in fact. Man, speaking of which, I wish Tyll was still around writing these days, or InnerFidelity would never have devolved into a clown show (which happened in thanks mostly to "audiophool" extraordinaire Rafe Arnott, who virtually banned half of InnerFidelity's original following from the site's comment section when they called him out for being manufacturers' lap dog) and finally the extinct dinosaur it now is.The first thing I do whenever I'm in the market for pretty much anything, or if I want to learn something about audio (or almost anything else), is to hop on YouTube to check out reviews. I'm hardly unique in this.
