I'm not sure exactly what you meant by that. Are you saying the Lindy Cables (Anthra, Cromo, etc.) use high-quality adapters but are not worth it? Or that Lindy cables are worth it even though they do not have high-quality adapters? Or something else?
One other quick note on the
Lindy Electronics cables for USB: from what I've read on their web site, the
only difference between the lower cost Anthra (Grey) and the more expensive Chromo line is the bling factor. If the cable will be out of view, get the Anthra. If the cable will be visible in a professional setting, get the Chromo because it looks better.
Based on very positive reviews from the RME crowd, all of my USB cables now are the Lindy Anthra line (since I don't need them to look fancy), purchased via Amazon. Here are links for each line:
