Kain
- Joined
- Feb 4, 2021
- Messages
- 288
- Likes
- 123
Say you have two different rooms. One is 12 feet long x 10 feet wide x 9.5 feet high. Other room is 22 feet long x 14.5 feet wide x 9.5 feet high. If I were to setup the best possible setup for a home theater in each room, will the larger room sound more "cinematic" or theater-like simply because of its larger size?
Smaller room has a 9.2.6 setup with Genelec The Ones all around and two large Genelec subwoofers + TV.
Larger room has a 11.4.8 setup with Meyer Sound speakers and subwoofers all around + projector with an acoustically transparent screen.
Will the larger room give a more impactful and theater-like experience? If I were to listen at very loud levels in the smaller room, will it overpower the room making it sound "bad"? Note, there will be appropriate treatments in both rooms.
Edit: Or even consider the same Genelec The Ones in both rooms (8361A for LCR and 8351B for all other locations). Will the larger room sound more cinematic or theater-like?
