I suspect that if one is a true believer in cables' various audible effects on sound quality once a cable has adequate R,L & C parameters to get the job done, that person will not be able to understand any technical explanation that shows that there is no audible difference at all, although test instrumentation may be able to measure differences in their RLC characteristics. So if you believe able A sounds better than cable B, then enjoy cable A. So long as you see cable A in operation while listening, for you, and for you alone, the sound will go through your belief filter and be modified by that filter to your liking. A rude awakening happens if unbeknownst to you someone swaps out your favorite cable with an adequate cheap substitute. You keep rhapsodizing about the sound even though a cheapie interconnect has been substituted for your true love behind your back. The gnashing of the teeth, the beating of the breast, and the clutching of the pearls starts after you discover what was done. Pedestrian RG58-U gits 'er done for me!I think the strong and false marketing of audio cables for headphones is successful because 99% of people don't look at the teardowns of their headphones and amplifiers.
In the first image shows the teardown of the HIFIMAN HE400se planar magnetic headphones. A simple, small section copper cable soldered by hand connects the 3.5 mm jack to the driver.
In the second image shows the teardown of the TOPPING DX5 II amplifier. Tiny copper tracks connect the balanced 4.4 mm jack, soldered by hand onto the motherboard.
Knowing this, how can you think that a headphone cable as thick as a finger and made of copper, silver, gold, diamond, uranium, etc. can improve the sound in any way? More teardowns for everyone and less marketing.
View attachment 476136View attachment 476137
