Wongdongfu
Howdy,
Hoping for a few recommendations. Or is what I am doing good enough! The speaker and amp combo sound great to me. But there is this itching in the back of my head saying if I get better amps I would get better sound.
Here is the current setup. I use this setup for both Movies and Music.
Preamp is Anthem Statement D2 – Amps are Marantz MA500’s – Speakers are Acoustat Spectra 22’s -
The Acoustat Spectra 22 Electrostatic Speakers that are being driven by (2) Marantz MA500 Mono blocks per speaker – (yes Marantz made a mono block that can bridge into another mono block of the same type allowing you to get more power into 8 and 4 ohms. (Both the Marantz MA 500 and Marantz MA 700 were bridgeable mono blocks) The Acoustat Spectra's are not efficient and are very power hungry.
The specs of these amps are below. The MA500 is no longer in production. My amps are 20+ years old but still seem to be doing great.. I am not an engineer so I can not specifically say that the specs on these MA500's are great or not. Reviews from the internet are good on these mono blocks. But again, I have the itch that I could get better sound with more current amps. Again I am bridging my MA 500s (2) amps per speaker.
Specs from the manual:
MA-500
Continuous power output (RMS)
8 ohm
20 Hz - 20 KHz <.05% THD 125 W
4 ohm
20 Hz - 20 KHz <.09% THD 180 W
EIA Dynamic power
8 ohm - 170W
4 ohm - 270W
2 ohm - 320 W
Bridged mode (2 x MA-500)
8 ohm
20 Hz - 20 KHz <.1% THD 360 W
EIA Dynamic power
8 ohm - 500W
4 - 600W
Damping factor at 8:
200
Frequency response 1 W 10 Hz - 100 kHz ± 1 dB
S/N ratio 116 dB
Input sensitivity/impedance 1 V/30 k
General
Power requirements 120 V, 60 Hz, 230 W
Dimensions W/H/D
3 5/16 X 5 1/2 X 17 3/4
84mm x 140mm x 451mm
Weight 14 lbs. 6.4 kg.
Again I think it sounds good to great. But I have the itch that It could be better – I would be willing to spend $2000 -$3000 (us) on an amp upgrade. But It would need to be appreciably better then what I am getting now. Slightly better is not worth it in my opinion.
Anyone have thoughts and or recommendations?
Thanks in advance
Jesse
MA-500
8 ohm
4 ohm
EIA Dynamic power
8 ohm - 170W
4 ohm - 270W
2 ohm - 320 W
8 ohm
EIA Dynamic power
8 ohm - 500W
4 - 600W
200
S/N ratio 116 dB
General
Dimensions W/H/D
Thanks in advance
Jesse
