If you use more than one input, or if you use the Rotel A10’s tone controls, then sure—it might be a good idea to use it as a preamp. Otherwise, probably not—but hey, you already have it, so you might as well give it a try if you want to test out a Class D amp.Thank you all for taking the time to answer my question.
Looks like the consensus ranges from No to probably not...
Some of you have suggested a Class D alternative.
I'm not convinced (old school, stubborn, plain dumb?) but I'm happy to try new things if they don't cost too much - and that seems to be one of class D's strengths.
If I were to get a class D power amp/s and use my A10 as a pre, would I be hearing 100% Class D sound? ie: would the Rotel simply be acting as a big selector switch for the source with controls? Or would it colour the end result?
Thinking a pair of Fosi V3 monoblocks might be worth trying to test the waters before committing to a "better" class D, or deciding I don't need more power.
BUT I don't think you'll hear any difference (unless you imagine it) between your Rotel A10 and a pair of Fosi V3 monoblocks.
If you haven’t already,... try using EQ; that’s where you can really hear the difference. Buy a WiiM Mini streamer/DAC for around $110; it has an automatic EQ function that measures and sets up an EQ/frequency curve tailored to your room and speakers. It’s a plug-and-play feature—super easy to use.
You can use your mobile phone’s microphone for measurements, but I recommend the UMIK-1 measurement microphone (around $130) for better, more accurate results.
Just make sure your tablet or mobile phone supports that microphone.
