Do I need a better headphone stand for my upcoming DCA E3?
DEF
As a headphone novice, does one need a stand, I found the table top quite convenient my children preferred the floor. ( where they left everything else) .
Yes but I want one if that rod I have is hurting a future E3. So will it hurt it?
it might, pressure is on one spot. They are quite expensive headphones i think it is worth to buy something to make them safe
Stick a bit of foam onto the rod if you're worried. I have a kind of similar setup - mine is resting on a long LED lamp.
