You offer the same explanation focusing on the shielding again, but I don't find that convincing at all. For any frequency not 50 Hz or its harmonics - yes, shielding could definitely avoid EMI in some situations. But the mains electric field is already inside the cable and inside your actual shielding - what would you be shielding it from, here? I'm looking for a plausible explanation why shielding a cable carrying a 50 Hz "signal" from other cables with the identical 50 Hz "signal" would yield any benefit.
In addition, inside your power strip and in the wall socket and wall, any mains cable will be unshielded again. The same applies in your switching cabinet and inside the amps and other devices. The shielding only covers the couple dozen cm in front of your rack. That's only a small fraction. You also mostly ignore all the other possible explanations for the 50 Hz peaks discussed in the thread, including a simple ground loop as well as contact issues (e.g. from slight oxidation) with the old cables.
I'll try to translate with Google Translate, so don't hold me back for grammar.
I was definitely misunderstood from the beginning.
I'm not for or against shielded cables.
I wanted to test exactly whether it does anything or not and what these cables do in my system.
The devices are new, the cables are of average quality, personally I exclude oxidation or other problems arising from the devices.
I actually measured before and after, then I chose to post the result here on the forum, at which point the world jumped up.
I wasn't asked further what was behind those cables, I only read that everyone already knows what I have in the system.
Let's clarify, I have an electrical panel dedicated to the audio system, I have an EMI filter in the panel, in addition to the SPD and dedicated routes for the powers in the audio system. Furthermore, I have a dedicated PDU with several outlets, which supplies part of the system.
Although the graphs show differences between the two measurements, I don't notice the differences by ear.
Because those differences exist, I decided to keep the dedicated cables, made by myself, which were not expensive at all.
Then the world got angry because of my translation that was made with Gemini, I thought it was ok, but I later understood from you that Gemini does not translate, but modifies my text, which I did not know, because I am not a native English speaker.
I hope I have clarified some of the problems.
I have a lot of tests and graphs, I can reproduce them anytime, so it was not a question of some defective wires or plugs. Or so I think.
