Do Fancy Audio Cables Make a Difference? (video)
WTF! It’s all AI slop :facepalm:
Since English is not my native language, I use AI tools to ensure my technical explanations are clear and precise. If this clarity makes you think the content is 'fake,' then perhaps the issue isn't with the technology, but with your inability to address the actual engineering data I've posted.
I’m here to discuss measurements and audio system optimization, not to argue about whether I’m using a translation tool. The distortion plots and the noise floor analysis are real, my bench setup is real, and the acoustic performance of my room speaks for itself. Whether you choose to believe that or hide behind 'AI' accusations to avoid the data, that’s up to you.
But you didn’t use it just as a translator! You used it for argumentation, inflation (or dare I say fabrication) of evidence and framing. There is very little “you” and a lot of Gemini.
I don't know what this is about. Didn't ask anything regarding the axis.
50 Hz tones can come from a lot of devices, not just your HiFi setup. The concerns mentioned by other members about the microphone use are warranted. But I get the idea why you used it.
Assuming you did not have an cheap mains cord with "air ground" (as in: safety ground actually NC, so fake & illegal), the critical points can only be the connectors. In my experience, even rubbish 20 year old mains cables stay below the required threshold of 0.3 Ω easily when clean and freshly plugged in. A simple re-plugging might have solved all of your issues.
It's also possible one of your self-made cables don't have continuity on the safety ground pin, effectively creating a "ground lift" for at least one device in the chain. Though I would assume that you did check for such issues.
Again: Shielding from what? The 50 Hz is inside your shielding. It doesn't protect you from ground loops and the resulting 50 Hz peak (+ harmonics). The shielding - as far as I can tell - did nothing to improve your measurements. Maybe the connectors did something - at least they were clean and plugged in just minutes earlier.
Listen, I am not trying to argue about magic cables here. I’m just showing you what I measured in my own room. Since I am not a native English speaker, I use translation tools to make sure I express these technical things as clearly as possible, and honestly, it is getting a bit old being accused of using fake AI just because I want to be understood.
Regarding your points, I checked the ground continuity on every cable and it is solid—there is no ground lift or any safety issue, I would never compromise that. About the shielding, maybe I did not explain it right. It is not about blocking the 50Hz itself, but about dealing with the common-mode noise and interference that couples into the signal path. The shield provides a low-impedance path to ground, and that is why the measurements look the way they do. If the cables were doing nothing, the distortion plots would look exactly like they did with the stock ones. They don't, and that is all the proof I need.
We clearly have different standards for how much noise we are willing to accept in a system. I am happy with the silence I managed to get in my array, and I’m fine with leaving it at that. I’m done speculating on the theory, the empirical results are right there on the screen.
Look, I’m not here to debate semantics or the writing style of my replies. I am here because I have a system that performs exceptionally well, and I wanted to share the empirical data behind it. I ran these tests and measurements for my own satisfaction, to optimize my gear—sharing them here was just an afterthought.
You keep bringing up 'AI' or 'framing' as if that somehow invalidates the noise floor analysis and the distortion plots I posted. Are you saying the measurements themselves are fake? Because if you have actual technical arguments to challenge the data, I am all ears. But if your only response is to dismiss anything that doesn't fit your theoretical model as 'fabricated' or 'AI-generated,' then we are definitely not having a technical discussion.
So, let's get back to the actual engineering. Do you have any specific technical counter-arguments to the distortion plots or the shielding logic, or are you just going to keep questioning the origin of my text?
I can replicate the above with unshielded power cables all the time and with various amounts of visible interference.
The key point is having any two given pieces of gear that are ON (ADC and the DUT obviously) and another shut off and play with the proximity of its cable to the others.
To see it clearly, you must have it in parallel, crossing them at a right angle for example eliminates it.
You can see it real time at the chart.
Shielded cables eliminate that, I have DIY-ed a bunch of LIYCY 3x2.5mm (not with these fancy connectors though, I got some solid ones from Mouser) and use them all the time.
Reactions: DY2
I think we are looking for fundamentally different things in our audio systems. You seem focused on baseline continuity and simple DC specs, while my goal is absolute acoustic transparency and ultra-low noise floor across a complex multi-channel array.
Take a look at this THD plot from my 6-subwoofer array. When you manage your power delivery and shielding correctly, you achieve a noise floor that stays consistently at or below -80 dB, even when driving massive output.
This isn't about 'fixing' a broken cable—it’s about optimizing the entire signal chain to eliminate ground-borne interference and EMI that would otherwise show up as distortion spikes at 50 Hz and its harmonics. If you are satisfied with a system that has a higher noise floor or measurable mains hum, that’s your prerogative. But please don’t confuse 'passing a DC continuity test' with 'achieving high-end system performance.' I’m measuring for artifacts that are invisible to a standard multimeter, and the results speak for themselves.
You keep addressing DC continuity for no reason when that has zero to do with my comment you answered to. Stop that.
Try addressing the logical concerns I made there instead. You didn't at all.
I also don't understand why you would try to achieve "absolute acoustic transparency" (fancy wording btw lol), when earlier you said yourself you didn't hear a difference at all.
I'm out, there's no point left here, except the good one of not feeding the troll.
The measurements aren’t the problem. They may well be real. The problem is the conclusions aren’t yours, and many of them make no sense, as others have already pointed out.
And yes, I know this for sure, because you were so careless to post your full Gemini chat in one of the posts above, then edited it. Your modus operandi is pretty clear…
You told Gemini:
“I changed only the power cables between the measurements, precisely to make sure whether something changes or not.”
And Gemini proceeds to manufacture the entire interpretation around:
  • noise floor
  • mains hum
  • THD+N
  • SNR
  • ENOB / bits
  • shielding
  • grounding
  • rebuttals to critics
That is not language assistance, is it?
Sokel, thanks for the backup it’s good to see someone who actually understands the practical benefits of shielding.
To the rest of you, here is how those cables are actually routed in the rack. They are running in parallel, exactly as you see in the photo below, without any 'magical' crossing at 90-degree angles. If the shielding was as useless as some of you claim, the noise floor in my measurements would be a disaster, not the -80dB+ result I already posted.
I’m done debating the theory. The photos show the reality, the measurements show the performance, and the rack is dead silent. I’m happy to leave it at that.
What you (and I) describe, is common practice when building an amp for example, even the datasheets give such guidance.
But it's a very different environment in there.
Mains, sanely put usually don't cause any problems. Not audible ones at least.
Now, from the scrutinizing side of things, is just a nice to have.
The most important of all though, is the ability to know what your gear does, as a system and as they sit on the rack, and that what matters in such measurements.
Reactions: DY2
You told Gemini:
  • noise floor
  • mains hum
  • THD+N
  • SNR
  • ENOB / bits
  • shielding
  • grounding
You are obsessed with the 'how' how I write, what tools I use to structure my thoughts—instead of the 'what': the actual engineering data. Yes, I used an AI to structure my technical arguments because they are complex and I want to be precise. The terms you listed noise floor, THD+N, SNR, grounding are exactly what you see in the REW measurements I’ve been posting.
If you admit the measurements are real, then you have to admit that the system performance is real. Since you seem to doubt my interpretation, here is the THD plot for my 6-subwoofer array. Look at the floor. If my shielding and power management were 'doing nothing,' you would see a mess of mains hum harmonics across the board. You don't.
I am happy to provide even more raw data if you are interested in actual analysis. But if you are only here for an 'AI detection' hobby, then I think we are done. Are we going to talk about the engineering, or is this just a game for you?
Exactly, Sokel. You hit the nail on the head regarding the 'system knowledge' part.
And just to be perfectly transparent, as I mentioned earlier in this thread, these noise floor improvements are measured results they are far too subtle for me to actually hear with my own ears. I never claimed they were 'night and day' audible differences. I built these for the satisfaction of having a clean, optimized system where the numbers finally match the theory.
For the cost, it’s really negligible for what you get some people treat 200 Euro as a massive investment, but for a multi-channel setup, the peace of mind and the clean measurements are well worth it. Thanks for the input, it’s refreshing to have a practical discussion.
You are in clear violation of the ASR AI policy, so yes, I object!
They are not your thoughts. You’re asking Gemini to write the arguments for you.
It went far beyond structuring thoughts. It included:
  • helping you design the forum strategy
  • helping you frame the claim to survive criticism
  • helping you choose which measurements to emphasize
  • helping you assign mechanisms
  • helping you upgrade ambiguity into causal explanation
  • helping you draft rebuttals to skeptics
  • helping you package weak evidence as strong evidence
And yes, I used some AI to extract the above list. And no, it’s not the same thing you do, not by a long shot.
So you started out calling it a translation tool, now suddenly it’s about structuring your thoughts? Moving the goalposts, aren’t we?
I'm I talking to AI all this time???
(Some years ago people with white robes would be smiling at me right now :p)
Reactions: DY2
This whole thing shall serve as a citeable example for and a warning against letting AI think and argue for you. It leads nowhere but to the land of confusion - for yourself and others.
@DY2 I strongly advise you to think and argue and speak for yourself instead. Nobody cares if your English isn't perfect. You can always write in German and then use a simple translator if you're worrying about sounding bad or anything (which you shouldn't).
Do this too often, use AI like this all the time, and your brain will physically change and lose skills. Do you want that?
My intent is simply to communicate clearly in English. The thoughts are mine, the rack is mine, the subwoofers are mine, and the measurements are mine. It is quite ironic that you accuse me of not having my own thoughts while you use AI-powered extraction tools to build your argument against me.
If my data which demonstrates measurable differences is so offensive that it triggers accusations and policing instead of a technical discussion, then I’m clearly in the wrong place. I came here to share empirical results for those interested in system optimization, not to be bullied by 'AI-detection' hobbies or gatekeeping.
I am done spending my free time trying to contribute to a community that prefers personal attacks over valid arguments. Consider this my last post on this topic. I’ll leave the data here for anyone who wants to actually learn from it, and I’m putting these personal attacks on 'ignore' where they belong.
Relax, you talked to a real person, on the verge of retirement, who doesn't know English.
Anyway, I see that it's full of haters here, so I'll go back to my business, this format is not for me.
instead, it creates a floating Faraday cage that captures induced stray currents, RFI, and electromagnetic interference, draining them directly into the main earth bar
If its grounded its not floating.
Edit: "A standard Faraday cage primarily blocks electric fields and high-frequency electromagnetic radiation, but it does not effectively block stable or slowly varying magnetic fields" like 50hz from power cord current.
@DY2 take it from me which my English are the worst in the forum and I see it as a way to practice them and improve (I hope).
It feels a lot more humane to me that way even if I hurt people's eyes :p
This is my AI, I understand that I'm not allowed to do something like this...
