Exactly, Roland. The markup on these boutique cables is pure insanity, and going the DIY route proves just how inexpensive the actual raw materials are.
Speaking of DIY and objectivism, I decided to run a controlled experiment to see if switching standard 230V power cables for my heavy-duty dedicated DIY power cables would show a measurable change in the system's noise floor and performance.
Just to provide the exact context for how these charts were captured, the measurement microphone, a miniDSP UMIK-2, was placed vertically on a heavy-duty stand at the main listening position using a 90-degree calibration file. The room temperature was kept strictly identical between runs. For the signal, I engaged All-Channel Stereo on my AVR to drive my entire layout of 12 speakers and 6 subwoofers simultaneously at a modest volume, playing a 1 kHz sine wave. The only variable changed between the sweeps was swapping the 230V power cables.
The RTA spectrum analysis in REW revealed a massive change. With the standard 230V cables, there is a major 50 Hz mains hum spike hitting -69.6 dBu, along with noticeable mains harmonics stretching up to 400 Hz. This heavy mains leakage degrades the overall metrics, resulting in a THD+N of 0.41%, an SNR of 33.8 dB, and an ENOB of 16.8 bits.
After swapping to the dedicated DIY cables, that 50 Hz mains spike and its surrounding low-frequency harmonics are completely wiped out, sinking straight into the noise floor. Because the mains contamination was eliminated, the THD+N dropped dramatically to 0.074%, the SNR improved by a staggering 14.1 dB rising to 47.9 dB, and the resolution officially crossed the 16-bit threshold, climbing to an ENOB of 17.0 bits.
To achieve this, I built a batch of shielded cables, bringing the total cost to well under 200 euros for the entire set shown below. The most critical factor in achieving this clean suppression of mains leakage was implementing a directional shield configuration, where the heavy shielding braid is terminated to the ground pin strictly at the wall plug side, leaving it floating at the IEC end. This successfully drains induced EMI straight to ground without creating any secondary ground loops between the chassis.
To remain completely objective and honest, subjectively at this modest volume, I cannot hear a difference. However, from an engineering standpoint, the dedicated cables clearly did their job in terms of shielding and suppressing EMI or ground-induced mains hum. In a complex environment handling a massive multi-speaker load, proper power routing clearly makes a quantifiable, textbook difference in cleaning up the spectrum analyzer metrics.
I would love to hear your engineering thoughts on how this massive reduction in mains leakage reflects on the electronics' power supply isolation.
