- Joined
- Feb 23, 2016
- Messages
- 20,759
- Likes
- 37,612
They have some 97 inch ones now, and I think I recall a 102 inch one will be out next year. Price isn't cheap......yet.Hehe @ ~12 foot OLED screens.
Yes, 4K or more is awesome I am told. I'm a shooter gamer on the PC so 1440p is the best compromise for high frame rates and resolution. I don't see a video card doing high frame rates at 4K or 5K. Not for less than maybe $3K. I'm not going there...lol
Silly me - just ran the same without looking back here, then recognised it when I saw the report.Site is rated B on https://www.ssllabs.com/ssltest/index.html.
Was just a thought and decided to check it... my subsequent suggestion then to Amir was more from a security perspective as TLS 1.0 and 1.1 are a security risk, 1.0 being non-compliant since mid 2018. An attacker could illicit connection failures or could trigger the use of TLS 1.0 to seek vulnerabilities like a browser exploit against SSL/TLS.However, neither Avast or Firefox bother about it.
First thing I'd do is create a restore point, then get Autoruns and check your startup for unneeded apps starting. You can also open a command prompt at type ping yahoo.com to see if your getting timeout errors, which indicates an MTU size that's too high. Also going into network properties and change your DNS server to 8.8.8.8 and secondary to 1.1.1.1 if it's your ISP that's slowing things down with their DNS server. An antivirus can slow that down too depending on which one and settings.I have a fast internet connection with minimal lag. When switching between tabs I experience delays in the switching and sometimes the open and playing music video in YouTube delays showing the video too. Is this caused by too many bad actor cookies? I permit all cookies for convenience. I have 32GB DDR6 RAM, Intel Core i5-12600K Processor 12th Gen Alder Lake and a RTX3070Ti vid card.
The internet connection speed test is rather low today and usually is ~500Mb for the download.
Yes. I have not overclocked the i5K processor yet as it still rules the RTX3070Ti very well and besides my new 1440p MSI 165Hz monitor delays the display turn ON and that combined with for some unknown reason I can't get into the BIOS. It's very disconcerting. I want to update the BIOS before I OC. Not sure if I should bring it to a proper techy. I have never needed a pooder tech since 1998 and to need one now is kind of bothersome.
