Do Audio Speakers Break-in?
I mean, come on guys... is this thread really still going round and round?
I know, right? The 'known' parameters of speaker break-in -- that it happens pretty fast, with woofers, on first use , if at all -- were mentioned early on. And yet people are re-reporting that now. While others are offerings us the same old anecdotes fatally contaminated with sighted bias.
And do I have to mention again, that without new unit-to-new unit variance data --i.e., knowing the normal 'spread' of measurements of brand new units off the same assembly line -- even interpreting actual 'break in' measurements is kind of a joke?
I hope I don't.
My vote: the horse is dead, Jim. More kicking won't help.
it is necessary as long as people neglect facts.
every-and i mean every- oscillating mechanical system will change it`s parameters over time and under load. even the silicon hairspring in your wristwatch or the suspension of your car.
speaker chassis are not excluded by magic from this. (far from it, plastics are prone to change parameters over time and under load)
frequency response is not the way to disprove this. thiele-small parameters should be measured.
Can you show those measurements which are very contradicting to the existing ones which show some of the lowest tolerances in the market and much lower than 1dB including crossovers where in my experience the typical tolerance of the components barely changes the response.
See black and red curves of below pairs:
Looked through the results and this appears to be new pair left/right matching vs old batch vs new batch matching, but in any case the matching looks good within 1dB or so. My SP1632 drivers are from the R900 so the manufacturing tolerances may not be as good. Also, I do wonder how aging may affect performance. The UniQ doesnt use ferro-fluid for cooling, which often degraded over time affecting performance.
But returning to the original posters issue of breakin vs manufacturing tolerances of the ATC speakers - it still seems more likely, to me, that manufacturing tolerances are the cause, and I would not automatically discount the OP claim, in the absence of measurements, that he could hear differences.
Well, no... Which is probably why the thread goes round and round.
TS parameters have been shown to change for at least 72 hours when burning in a new, raw woofer with a sine wave at Fs near xmax. This does not PROVE that the is an audible difference after break in. But it provides a scientific reason why it could. See the KEF paper.
Well, no, not sufficient.
How much is it changing from hour to hour across 72 hours (i.e., the rate) ? And how does the delta compare to the delta of out-of-box units?
I know you're aware that measuring a change alone doesn't make it perceptually meaningful.
Anyway, I still say shut this thing down. It's a pointless circle, um, exercise, by now, and the wild claims of 'broken in' sound are still just that. Even after decades of advocates knowing what was required to make a convincing case for them.
Don't forget the drive units are not 'virgin' when you unbox the speaker. Drivers tested before and after installation, at least by any speaker manufacturer that's doing things properly.
And who is doing that, exactly?
I wrote it before, the smallest summary possible: I bought new ATC SCM19’s, it took some time before I liked them, discovered that the painting was not flawless, it took months before the replacements came, then suddenly the months-old were replaced by new ones, the decrease in sound quality was shocking and I had to wait again before the sound recovered.
Note: ATC states that their speakers do not need breaking in. My conclusion: rely on your own ears and surely don’t listen to people that draw conclusions based purely on measurements.
Your anecdote based on sighted listening and your perceptual bias, is totally uncompelling given the dozens hundreds of measurements showing that driver break in effect is tiny, occurs in the first few moments of operation, the actual changes in parameters are below inaudibility, the tiny changes that do actually occur and cancel each other, and the nature of the changes does not systematically make it sound better even if the changes were audible.
It's particularly absurd given ATC QC's every driver. Does the end-user really think they have some magical tones they play that ATC doesn't have access to that somehow break the driver in in a way ATC is incapable of doing? And apparently every person who has ever tested driver break-in?
I noticed that many ascilab speakers recommend "break-in for optimal performance", since Amir is a distributor for them I got curious, is there any truth to it?
Ask them to share the measurements that show they change over the first 24-hours, and that the changes result in optimized performance.
Amir started this thread, did you read his OP and understand his data?
I asked KEF when they made similar unsupported claims in their marketing material, with no evidence and despite much evidence to the contrary.
Yeah i got the gist of it but since he distributes these I got curious, maybe they meant something else? Thought it's worth asking
But I think it entirely possible that woofer surrounds and spiders might change characteristics over time with use.
They do, but it is only an extremely minimal change as things loosen up. Loads of measurements have shown it.
Audible, I'd highly doubt it, but even then only possible if done under bias controlled A-B between a virgin and well used.
And never would it be a OMG, "its a completely different speaker after a week of breakin".
That's a brain perception issue. ;)
Maybe, but the better target to ask would be @AsciLab.
Reactions: MAB
