Do Audio Speakers Break-in?
that's another story, and yes, drivers vary from batch to batch and it affects almost all moment - TS, frequency response and impedance what is quite important while speaker designed. While it is within tolerance what manufacturers have, we still need to re-measure drivers to get matching pairs and then match it to tweeter and sometimes re-adjust crossover for optimal result. Big job and long process to get everything done right.
... and no problem at all when designing active speakers.
The driver change TS after break-in and it affects how it works with existing cabinet volume and port. If you break-in ported speaker it can easily go to xmax and break-in takes some 10min. If driver is mounted in sealed cabinet it may take longer.
But not much longer, really.
And this isn't news. (Nor does it account for normal sample variability)
It certainly does not address the usual claims or recommendations for break-in.
So the real question is, why did you even bother?
Maybe someone can build an ASR_AI bot that tells posters "This has already been discussed/this point has already been made [here] and [here] and [here]."
I think the result would be that the forum can be shut down. We never see anything new.
There will always be new reviews.
And people asking us to explain their REW results for them. (I plan to be one of them in 2026)
And of course the Mystery of the Vinyl Renaissance will continue to beg for answers which will be immediately forgotten as if a black hole had un-existed them.
So there's that.
I couldn't sift through every page ... But what I have not seen enough of is a discussion on the reason there's a gap in the first place between people who think break-in is real and the science that proves it isn't.
Psychoacoustics. It's not the speaker that gets broken in, it's YOU.
When people report that speakers really really do “open up” after hours, days or weeks, the dominant variable changing is not the speaker (measurements prove this), it’s the listener’s internal reference system that changes ( biological science proves this - it's a concrete example of brain plasticity). This incidentally is why recorded music can't be used to accurately judge the performance of a speaker. Your ears burn in and become accustomed to the tonality of the speaker, and will accept it as "normal" after a while.
I remember one time mixing a good chunk of a song with the wrong curve adjustments on my speakers. I had them calibrated to my headphone's curve by mistake. Because I trust my speakers, I didn't think anything of it and my ears became accustomed to the wrong tonality. I didn't realize it until I listened on a different playback system and wondered what the heck was wrong with my ability to mix. It's SO easy to be fooled by the sound a speaker makes. This is why hard scientific evidence is needed to tell us the truth about our speakers and audio gear.
Your auditory system does continuous, automatic normalization across several dimensions, just like mine did when I tricked myself into thinking my speakers were tuned neutral when they were objectively not.
  1. Spectral balance (tonality)
  2. Loudness vs frequency (equal-loudness perception)
  3. Spatial cues (precedence, interaural differences)
  4. Expectation and attention weighting
This process is well-documented in psychoacoustics and is fast, powerful, and mostly unconscious.
This is analogous to adapting to new glasses or stepping into warm/cold water. What feels odd at first becomes normal relatively quickly, unless you are dealing with extremes - in which is just takes longer for your brain and body to normalize to the stimulus.
Did I think something felt off when I started listening to the headphone calibrated speakers? Yes. But I ignored it because I am biased toward "I trust my speakers" ... So I wasn't dilligent, and that lead to believing a bad mix was good, until I could re-contextualize my work on a truer to reality playback system.
I set up 3 new Focal Diablo Utopia Colour EVO speakers today. These were replacements for the 3 Diablo’s I picked up in early March 2025. They had some minor cosmetic blemishes on the top and Focal agreed to replace them. I may have never noticed but the speakers are directly under can lights. Otherwise, they always functioned perfectly and sounded fantastic.
There were a couple missed attempts I won’t detail but Focal kept with me until they got it right and the new speakers finally were delivered and look flawless.
Today I got to hear how much break-in new speakers really need since I replaced identical speakers. Focal's web FAQ recommends playing for a couple days or 50 hours and expect subtle improvements after that over time. My dealer said it takes 200 hours or more. I always felt like a lot of break-in was getting used to the way new speakers sound. I am thinking that is pretty close to true as the speakers out of the box already sounds as good as the ones I switched out.
I will wait 200 hours anyway and then decide if I want to take the time to run Anthem Room Correction again on my STR Stereo Preamp and AVM 90. For now, I'm playing multi-channel SACD's and DVD-Audio discs through the Anthem AVM 90 to give all three Diablo's work. If I want a placebo confirmation, I want to do it while listening to good music.
Bottom line, in my room, I can’t tell much if any difference in how they sound. I did notice a big difference after replacing my Dynaudio Contour 20’s with the Focal Diablo’s back in March 2025.
a well trained AI can be a good way to combat subjective BS though, because they just repeat same arguments over and over. a well formatted and adapted response backed with facts and references could be a good way to stop them right there
Given that people tend to trust AI output more than actual subject matter experts, no matter what stupid nonsense it comes up with, that might very well be true. And with a bit of prompt engineering, you can get half-decent advice even on audio subjects, rejecting the subjective nonsense.
Didn't read the whole thread but seems odd that the audiophiles who believe in really long breaking periods never seem to worry about their gear getting  too broken-in.
break-in is ALWAYS good, if you have worse sound after a while it's cus your ears aren't golden enough! Maybe buy a musical amp!
evidently critical thinking is not their strongest suit
I can tell you anecdotally that I recently bought KEF R7 Meta speakers and was disappointed upon first listenings and after listening to some music and TV over a period of days, they sound significantly better and i'm very happy with them. I certainly wasn't waiting or looking for them to sound better and always thought break-in was a well established myth. But I have no doubt that they don't sound now like they did when I first started listening to them.
You don't even entertain the possibility that your brain has stepped in rather than any audible difference ?
Speaker "break-in" is like all break-in theory.
When does break-in stop?
If the supposed break-in process occurs over some variable defined component time when does it stop?
Why doesn't it progress until it's "broke".
It's in your mind.
Our brain has a break-in period too. But I think it entirely possible that woofer surrounds and spiders might change characteristics over time with use. Midrange drivers & Tweeters? I don't see it but I would like to see studies on this topic- maybe they too "wear in." Surely speaker system or raw driver manufacturers have this data.
Good point about "break-in theory" -- when one reads the audiophile magazines, break-in only ever gets better. It never gets worse. That alone defies logic.
Meanwhile, some of the marketing professionals I've known over the years uniformly state that the goal is to get customers to use their product for a couple of weeks to a month. That's how long it takes for that product to become the new standard reference in someone's mind.
I agree that measurements are a good approach to testing this.
Soundwave measurements, that is, if you are talking about sounding different.
I would have thought it would be obvious, the KEF paper linked above touches on it. The soft parts of the speaker break-in, which appears to be accepted as fact in this thread. Anyone who has ever measured TS parameters knows that if you burn in the speaker the TS parameters measure differently - why would anyone expect this to NEVER make an audible difference?. Speakers are measured and designed with broken-in drivers.
  • It shouldn't be surprising if a speaker doesn't sound audibly different after break-in, as the break-in just wasn't signficant
  • It shouldn't be surprising if a speaker DOES sound audibly BETTER after break-in, as it sounds the way it was designed to sound after break-in
  • It would be surprising if the speaker sounded WORSE after break-in.
