The driver measurements I see indicate the break-in effect occurs in the first few moments of operation, is measurable but very small and inconsequential to the reproduced sound. Perhaps link the actual research you mention.I would reject the report because the people involved apparently haven't looked into the industry at all, where such things have been intensively researched for well over 50 years.
Industrial membranes and certain surrounds are very similar to loudspeaker drivers in terms of function and materials. The measurements show a stable operating point after approximately 50-200 hours, depending on the material, even more. However, the stresses are higher, and lower stresses prolong this initial aging process.
No, the primary material property changes occur in the first few moments. Andrew Jones discusses this:Based on this, the stated 3 hours are far too short, and the result is very questionable in my opinion.
Vance Dickason discusses this in his books; that while driver break-in is measurable, it happens early in operation of the driver, and are tiny:
Dickason indicates the real reason to test drivers prior to installation, defects and out of spec units. Which is my experience, as can be seen below if you carefully read the posts."As can be seen, the changes in box performance are trivial."
Vance Dickason, Loudspeaker Design Cookbook, 6th edition, Chapter 8, Section 8.20 (Break-In) page 155
Yet you dismiss without evidence.I only skimmed the whole thing, but perhaps I missed something, and they also conducted tests after a few hundred hours.
Perhaps show this. I was really surprised to see this old urban legend of driver break-in was alive and well at ASR, despite the observations of Dickason and Jones and other speaker experts, and despite how easy it is to actually test this. I was also surprised at how many members cling to the idea that break-in is a significant issue.Did they also consider the different materials and material pairings? For example, the two extremes in midrange and woofer drivers? Foam surrounds in conjunction with very soft spiders, or thick rubber surrounds with very hard spiders? Or what about cone materials like polypropylene, glass, Kevlar, carbon fiber fabric, paper, sandwich compounds, etc.?
All these materials change to a greater or lesser degree. Some become softer, for example, fabric-based materials, while some plastics become harder and more brittle due to the outgassing of plasticizers and solvents. Not to mention the effects on resonances.
So I tested, some are in this thread. Others are here:
Speaker Break-In and Environmental Measurements
The subject of speaker break-in comes up often. It's also called run-in. It's different than aging, or wear-out. I see people posting YouTube videos of woofers being deformed into the shape of a potato-chip, while the 'tuber yells at me to make sure and break in my drivers before ever...
www.audiosciencereview.com
I tested it's replacement that was shipped to me, it had break-in that was tiny.
So yeah, driver break-in happens but is tiny. And as Dickason says, the main reason for doing break-in testing is to weed out discrepant or defective drivers, which involves testing before and after break-in. It's certainly unfortunate since driver break-in is one of the old tricks in the book used to shame customers into keeping bad sounding speakers. "It will always sound better after break-in."
