MaxwellsEq
- Joined
- Aug 18, 2020
- Messages
- 3,597
- Likes
- 6,384
Yes, I will.@MaxwellsEq You can do it in three days, in a week, as you like … one test per day. It is still valid.
And thats clipping "about 1% of the time" not 1% distortion, which is confusing. How that correlates to PMAs test with some clipping is rather obscure.As I noted in the article though, I don't know how they determine the 1% in the age of analog scopes and dynamic music. So I don't consider this very trustworthy but for transparency, I included it in my write-up.
You can also look for clipping.You would need to measure distortion to know what maximum power is. How would you measure distortion with pink noise?
Yes, that's closer.I don't enjoy repeating the same spiel of mine on the "power" term, but I would repeat this for convenience. So, I guess the test your keep asking for might actually be: What's the maximum Voltage and current the amp can deliver, with pink noise input, and for what duration?
I don't think power should be use in this case, because people (as they always popped up and saying something...) would say it is not the "watts", but current that we need to worry about blablabla..). The fact is, if the max power is say 500 W into 4 ohms with test duration lasting 2000 ms, it would seem like a good number but we would not know how much of that 500 W was dissipated in the amp's output stages. One way to get around that would be to do something like the "power cube" (imo outdated..) tests, or Amir's reactor load test (I prefer that) and I assume you probably referred to that test, but one that last longer than a few ms, and with pink noise instead a 1 kHz, am I right about that?
Depends on the noise.IMO such request is pointless in case of amplifiers. It makes sense with speakers. Music cannot be substituted by a pink noise. Only short passages might be considered such, especially when DR is high. Such pink noise power parameter for amplifiers would be misleading. Noise is a stationary random signal. Music is a non-stationary transient signal. Quite a big difference.
If you look at the settings of the FSAF test I posted, CF is about 15dB for the PN, that's far from stationary.
(REW also warns you about it if you set test level too high)
Careful about this version of ABX test. It is designed to make you fail such comparisons more than succeed.
The change came about some 10 years ago when there were a number of blind audio challenges being posted online. I passed many of them with then ABX plugin shocking many people who thought these challenges were impossible to pass. I explained during the arguments that ensued, how I would find the critical segment in a clip by trial and error. Once there, I would then run the full test and pass it. This was enabled by the previous version of the plugin providing the information as to whether you passed or failed in every trial. This way I could identify the segment and see if i could pass it in the next trial. If I failed, then I would go to find another segment.
I agree. After 5 listens then 16 ABX comparisons with IEMs I "felt" I could sense a tell. The ABX says I failed statistically to detect a difference.....which, as I've argued before, is a method and a result that has absolutely f*ck-all to do with the bog-standard, extremely common sort of difference-hearing claim that (sighted) listeners have been making since home audio became a thing and which you'll find in every issue of Stereophile and every day on WhatsBest?
And after you've forensically trial-and-errored your way to a reliable 'tell' -- a tiny sliver of music that reveals a difference in instant A/B switching, -- can you go back and still reliably 'tell' the difference, blind, when listening to *the rest of the music*?
says nothing if you can go back and still reliably 'tell' the difference, blind, when listening to *the rest of the music*? In fact, the answer is NO. During normal listening there will be no difference. And that "tiny segment" is often chosen as cheating, like if the tiny DC shift suddenly disappears at the end of the music sample, resulting in audible click. Or enormous gain used to amplify the initial part of the music sample. Been there, seen that.a tiny sliver of music that reveals a difference in instant A/B switching
The current method of foo abx is correct, the previous version that was providing the info between the trials was not. It is a DBT test, not the hint test.
And I completely agree - that
Phono and microphone amplifiers may measure and even sound different, but line-level preamplifiers are not challenging.Very interesting reading through all this. I am in the process of ABx testing mc 501's (that some on this forum helped me get going), vs Hypex NCx 500, driving 802d's, but not able to make much progress due to lack of help keeping things "blind". I'm curious to hear if we can expect a similar split with pre-amplifiers? As in " do all similarly spec'd pre-amps sound the same"?
Try thisI have an amp that generates 0.2% of H2. I can identify it reliably.
The question loses a lot of detail.
What’s the THD+N threshold assumed?
I think he's saying it emits hydrogen. In which case evacuate the neighborhood.Your amp emits deuterium?
Remarkable.
H2 (deuterium) is an isotope of hydrogen.I think he's saying it emits hydrogen. In which case evacuate the neighborhood.
