IPunchCholla
- Joined
- Jan 15, 2022
- Messages
- 1,405
- Likes
- 1,949
I’ve tested my hearing for FR response, harmonic distortion sensitivity, and noise sensitivity. I know within a few dB how much of any of it I can hear. And I can’t hear the difference between my ADA 150 and PA5. I can hear a difference between my speakers in different rooms and between different speakers in the same room. And every difference is accounted for when I measure.Don't ask me - I'm not an amplifier designer.
Don't tell me that an amp designed doesn't ask people to listen to and comment on its sound before they release it on the general public. Beta testing, etc
If you can't tell a great sounding amp from a good sounding one, get your hearing fixed, rather than look at measurement to offer the answer.
As a producer of music I have tricked myself into hearing differences when there are none (adjusting volume on tracks that were muted, adjusting the volume on a sub that was off). I know I can be trivially misled by my senses if I don’t apply rational checks on them.
When I joined this site, I didn’t know ohms law. Since then I have learned enough to design electronics and build them. But you don’t even have to go that far. There is free software that lets you build any electric circuit you want and pretty much every component is modeled for download for free. I have now designed and simulated class A and A/B amps. It really didn’t take too long to learn.
In the process what I found out was there is no mystery to any of this on the electronics side. It’s a totally solved problem. Everything that goes into an amp is understood far, far, far past humans ability to hear.
Claiming you can hear things that can’t be measured in an amp circuit is like saying you can see further than the Webb telescope.
It needs extraordinary evidence, not just a simple, “because I said so.”
