tokyo_blues
- Joined
- Jun 30, 2022
- Messages
- 70
- Likes
- 62
- Thread Starter
- #61
@tokyo_blues did you mention your listening room size by the way?
Sorry, no I didn't. Approx 7x10m.
How high is the room?Sorry no. Approx 7x10m.
another good example of de gustibusThanks - they're not floorstanders, and while I think they look good, they don't fit the room so WAF is inexistent. I wish Genelec could partner up with Sonus Faber etc:
or this
or
these are not my cup of shellac
Ah, I see. You want something that is more boutique furniture style.Thanks - they're not floorstanders, and while I think they look good, they don't fit the room so WAF is inexistent. I wish Genelec could partner up with Sonus Faber etc:
or this
or
Bruno Putzeys says this, not me. I bet you are way smarter than him.It's dangerous nonsense to write something like that, because some people might believe it. If the speaker chassis can't handle the excursion and power handling, they will simply be mechanically destroyed. It's that simple. And before they burn out, they will distort heavily in the range before destruction. Even with high excursion capabilities, a small driver usually has a smaller displacement volume and a smaller voice coil, which results in lower mechanical power handling.
For tricks with the DSP, which the driver is reluctant to follow in a passive crossover, you need very resilient speaker drivers with a large headroom. As a rule, I only work with frequency reductions, not boosts, in active speakers.
If I want to raise and amplify the bass range with DSP, I only use very resilient PA drivers of the highest quality with large displacement volume and high mechanical and electrical resilience.
You can't outsmart physics. If you want high sound pressure and deep tuning at the same time, you need a lot of membrane area and large excursion capabilities. It doesn't matter whether active or passive. Only with active speakers can you interpret the Thiele Small parameters a little more generously.
Yes, the safest and best option is to build a passive crossover using only air coils and film capacitors—but that is expensive.
These are a good and relatively inexpensive option if you're looking for new speakers.
Heco Celan Revolution 9
Test Hochpegel-Standbox Heco Celan Revolution 9 - LowBeats
Auf den Norddeutschen HiFi Tagen 2019 machte Heco Vertriebsleiter Mario Lode ein interessantes, aberwww.lowbeats.de
An active system can typically do some trickery to extend lower in the bass, but not at unlimited listening volumes.
Yeah, meanwhile producing a lot of distortion and/or compression, because small drivers (and cabinets) are ... small, no matter what.By contrast, an active system can "look ahead" at the music, adjust the drivers in real-time to prevent damage, and use heavy amplification to force small drivers to produce massive, accurate bass that would be impossible in a passive setup.
I think all of these are speakers that can make you happy. For me personally, it would be important to be able to listen to ready-made speakers beforehand, preferably at home or in a room that is roughly the same size as my listening room.Do you have a comparative opinion on these?
I only have speakers that I have built myself, most of which are active.
Sigberg and I happen to have a very similar idea of how a speaker should be constructed, which I have noticed here on ASR.
I also prefer to use PA coaxial speakers with a very powerful and adjustable subwoofer. All of this is activated and controlled via DSP.
For me, this is the best solution, but I can understand that not everyone wants to learn about measurement technology and speaker construction and is looking for a ready-made solution.
Even Bruno Putzey and you can't outsmart physics. If you want high sound pressure and deep tuning at the same time, you need a lot of membrane area and large excursion capabilities. It doesn't matter whether active or passive. Only with active speakers can you interpret the Thiele Small parameters a little more generously.
You can use active solutions exclusively to make something that is already good even better, but you cannot perform miracles with them or, for example, transform a poor chassis into a high-end speaker.
You can believe that or not, it doesn't change the physics. If you think you can achieve the same sound pressure and bass depth with any Purifi 6.5-inch chassis and a 2-kilowatt amplifier with DSP as with a well-tuned 15- or 18-inch long-throw chassis in passive speakers, then good luck and go for it.
I think the summary you posted is from an AI.
No, I'm not a dealer.Thank you. I see you're located in NRW, Germany. I live in Aachen. Do you sell your speakers? Do you know of any local custom speakers makers where I could go for a listen and discuss design/buy direct?
www.acoustic-design-magazin.de
I think we're always on the same page when it comes to speakers, ThorbjørnI feel like we are in agreement here, I hope I have not implied otherwise.
