Secondly, does is stream Ap[ple Music, I noticed a reference to that nut someone said it streams it in lower resolution.
Thirdly, Is it relatoibel simple to use?
fourthly (fourthly?) had anytne attached the ssd card to the unit and use it to store discs and what kind of cd writer did you use for that?
Thanks
Dennis
On Apple Music: There are 2 ways to use Apple Music with this device (I have an A8 and an A6 first generation, they both work the same in this regard):
1. Use the native Apple Music Android App on the device - with this, you control on the screen, or via your phone using ever solo app with the "screen" app, which is basically like controlling screen sharing software. Your phone/iPad/etc is just controlling the screen the Eversolo. This allows full Apple Music high resolution lossless playback (you'll stream the highest resolution available for the music and the device will show you the bitrates), and it works well. You login on the Eversolo app with your Apple Music credentials. This app you are using is built by Apple and distributed to Android devices (which the Eversolo is under covers)
2. Use the Apple Music interface on the Eversolo. The difference here is this is using an API to connect to Apple Music directly, and the streaming is limited to lossless CD quality (ie 16/44.1). It won't stream high resolution Apple Music. however, the app and interface are generally nicer to use and easier to control
I find for casual listening I'll use the native app interface (item 2) as I am fully apple ecosystem and the control, interface etc on the phone is really good. Eversolo has done an excellent job with their client software, it's gotten very very good over the last year. If I want to stream in high resolution I'll use the Android app on the device (item1).
Easy of use: It is easy to use for most functionality. I think for most users the hardest thing to do would be moving a music collection to an SSD to play back internally and setup the device to read the source. its not hard, but, it might be a bit technical for some users. I have a very large music collection so I found it easier to copy my library on an external SSD drive enclosure and then install it into the ever solo vs. using a network share to copy the files which was quite slow (for 3TB+ of music). However once on the SSD installed on the device the use and playing of music and the interface is excellent and easy to use. There are a few steps: install SSD, get music to the SSD, point the playback app to the location of the music on the SSD, scan the library). Then you just playback.
On an external CD player, I have a quite old external Samsung USB CD reader/writer. I used this many years ago to rip my CD collection. I plugged it into the ever solo and it recognized it, I could play cds from it, and I could rip cds to the internal drive or SSD inside the unit (note that the A6/A8 has one SSD slot, but you have to supply the drive).
So I think most USB compatible CD drives will work fine for this purpose of ripping CDs to be stored on the unit.
