DIYSG HTM-12v2 Review
hardisj
Reviewer
North Alabama
This is a copy/paste from my site and there may be formatting issues here because of that. You can see the full review on my site.
https://erinsaudiocorner.com/loudspeakers/diysg_htm12v2/
DIYSG HTM-12v2 Speaker Review
  • Saturday, Jun 12, 2021
The review on this website is a brief overview and summary of the objective performance of this speaker. It is not intended to be a deep dive. Moreso, this is information for those who prefer “just the facts” and prefer to have the data without the filler. Discussion about the data and my subjective thoughts can be found in my video below.
For a primer on what the data means, please watch my series of videos where I provide in-depth discussion and examples of how to read the graphics presented hereon.
https://youtube.com/playlist?list=PLnIxFR_ey0b37Ex4KV2mBz-kYB7QLffR1
Information and Photos
The DIY Sound Group HTM-12v2 is a DIY design from Matt Grant which was/is available in kit form from DIYSG.
Note the distinction of this model is “v2” as this is an update that was made from the previous version in 2020. The speaker is ported (front) and the crossover point between the Celestion CDX1-1742 compression driver and the (Eminence made) Denovo 12” Hyperlite™ woofer is specified as 1250Hz. Assembled weight is approximately 36 pounds according to the designer.
Here is a quote from the designer:
The new HTM-12 is the most capable of the current HT(M) lineup and suitable for use in very large home theaters. Even though it’s the largest and most powerful of the HT’s it does so without compromising sound quality. It uses a new Celestion compression driver with a polyimide diaphragm providing smooth yet detailed high frequencies, and the 1.75” voice coil handles extreme dynamics and high output levels with ease. The new 12” Hyperlite™ woofer is the end result of a 1.5 year joint project with Eminence. The Hyperlite features a completely new surround and spider giving the woofer more X-max and lower bass output. Completely frame and cone give a stealth look with no reflections while watching a movie. The Hyperlite™ woofer specs along with its high powered neodymium magnet give this speaker a very well balanced and detailed sound over the bass, mid-bass, and midrange. The large SEOS-15 waveguide has excellent directivity control for a very wide “sweet spot” so everyone hears the same thing without any significant changes in sound no matter where they sit in the room.
A kit for a single speaker (including everything sans enclosure; except for front baffle) was approximately $330.
These speakers were loaned to me by their owner, who built them from the kit. There are no physical or electro-mechanical issues and this unit is a good sample, representative of what one would ideally build from the kit.
The reference plane in this test is just below the tweeter, per the designer, Matt.
CTA-2034 / SPINORAMA:
Early Reflections Breakout:
Estimated In-Room Response:
Additional Measurements
Impedance Magnitude and Phase + Equivalent Peak Dissipation Resistance (EPDR)
For those who do not know what EPDR is (ahem, me until 2020), Keith Howard came up with this metric which he defined in a 2007 article for Stereophile as:
… simply the resistive load that would give rise to the same peak device dissipation as the speaker itself.
A note from Dr. Jack Oclee-Brown of Kef (who supplied the formula for calculating EPDR):
Just a note of caution that the EPDR derivation is based on a class-B output stage so it’s valid for typical class-AB amps but certainly not for class-A and probably has only marginal relevance for class-D amps (would love to hear from a class-D expert on this topic).
On-Axis Response Linearity
“Globe” Plots
Vertical Polar (Globe) Plot:
Harmonic Distortion
Harmonic Distortion at 102dB @ 1m:
Cumulative Spectral Decay (CSD)
  2. 86dB at 1 meter (red)
  3. 96dB at 1 meter (blue)
  4. 102dB at 1 meter (purple)
Long Term Compression Tests
Parting / Random Thoughts
  • Subjective listening was mainly in the farfield at 3-4 meters in an open floorplan living room. Subjective listening was conducted at 80-95dB at these distances and occasionally higher. Higher volumes were done simply to test the output capability in case one wants to try to sit further away.
  • The sensitivity of this speaker is lower than the v1 version by about 3dB (v1 measured at 94dB @ 2.83v/1m, where the v2 measures at 91dB @ 2.83v/1m). In this case, however, I’d happily take the tradeoff of sensitivity for better frequency response. You’re already in the low 90’s and that’s plenty for most home theater setups. The fidelity is better to have than 3dB sensitivity in this case and in my opinion.
  • When listening, I was mostly overall happy with what I heard. The horizontal radiation pattern is fairly narrow (as the data shows) and this tends to keep the speaker from having a very wide soundstage as there is little reflections from the sidewall to help enhance the feeling of spaciousness in the recording. However, some may prefer that (or some rooms may be better served by a speaker like this). The one issue I have - sonically - with these speakers is the amount of lower midrange resonance. This is clearly audible and the CSD data points to the issue being in the ~250Hz region, evidenced by the long settling time of the signal compared to other frequencies. My guess is this is a function of the enclosure height, as the height (25 inches) is equal to a half-wave of about 270Hz. There is another resonance that shows up in the impedance at around 400Hz which seems to also correlate to the width dimension of the enclosure. It is possible additional bracing or simply adding additional acoustic stuffing would remedy these issues.
  • The dynamic range (Instantaneous compression) data hints at some potential areas for improvement.
    • First, at around 1250Hz the compression peaks at about 0.5dB. We know this is the crossover point. The harmonic distortion data also shows an increase there. Most would look at this and think the crossover is too low. But it is important to realize the level of compression we see; it is roughly 0.50dB at 102dB. Is it worth messing up the excellent directivity at the crossover region in order to relax the compression to a smaller number? I don’t think so. But if one wants to put some more money into things, then maybe. Of course, this could be heating of the actual passive components, though my hunch is we would see that show up in the long-term compression tests and we do not.
    • Secondly, there is some funny business going on around 400-500Hz. Looking at the impedance data we can also see some irregularity there evidenced by a “blip”. This indicates a resonance either from the woofer itself or the enclosure. I would have to measure the raw woofer out of the enclosure to know for sure.
    • In the low frequency we see compression increase below about 80Hz but from 80-100Hz the compression is pretty much flat. Around 100-200Hz there is some more compression. This leads me to think we are seeing raw driver effects and simply reaching the limits of what this speaker is capable of on the low end. Even though it is a 12-inch woofer, it is on the higher-side of sensitivity and we expect to lose output on the low end compared to a traditional 12-inch woofer.
  • The high frequency above about 6kHz tends to widen in directivity which means it could potentially sound a bit bright. I’d consider using some acoustic absorption on the sidewalls that would help absorb some of this but I wouldn’t go too thick. I think - and this is pure speculation - that 1-inch thick acoustic paneling on the first reflection points would make a positive difference here. Though, with that said, some people prefer a little bit of treble. In my own opinion, however, this extra “boost” isn’t ideal.
In my opinion, this is a significant step up from the previous “v1” iteration of this speaker.
While the response is not flat by any means, the directivity control of this speaker is excellent. There are midrange nulls - but in every axis. This means that with a little bit of EQ to straighten out the kinks in the midrange, you end up with a speaker that has a more linear response and does so in every axis, spreading the same energy to the sidewalls as it does directly at the listener making for a more pleasant sound for music and home theater alike.
Even in its raw form (without EQ) I’m quite impressed with what this speaker does. If the designer can figure out what is causing the dips mentioned above and can also fix the resonances I am hearing in the low midrange, I imagine this will be a world-class speaker besting what highly-regarded manufacturers produce at a significantly higher cost to the user. However, it should be noted these issues may increase costs. I just imagine what it is capable of with a little more money put into it either via passive components or even DSP.
This is an obvious “recommend” from me given the target, the performance and the potential to be even better with some DSP.
Support / Donate
If you like what you see here and want to help me keep it going, please consider donating via the PayPal Contribute button below. Donations help me pay for new items to test, hardware, miscellaneous items and costs of the site’s server space and bandwidth. All of which I otherwise pay out of pocket. So, if you can help chip in a few bucks, know that it is very much appreciated.
https://www.erinsaudiocorner.com/contribute
You can also join my Facebook and YouTube pages if you would like to follow along with updates.
Rick Sykora
Stow, Ohio USA
Any nearfields? The lower midrange resonances could be from port(s)…
Reactions: Zvu
napilopez
NYC
This looks like the perfect starting point for an active design! But even without that, a high resolution EQ could get you close to state of the art performance. They did an excellent job with directivity on these. These look like a great DIY option if you can implement those final few tweaks -- or if you just want sensitivity on the cheap.
hardisj
hardisj
Reviewer
North Alabama
No. If the port is simply leaking the internal resonance from standing waves then people will think the port is at fault. We won't know for sure unless I plug the port and test which I didn't do for this speaker (but I did do for the Pioneer VM-50 I just posted). So, I hesitate to post nearfield graphics until I have the chance to try it both ways.
xarkkon
i'm a simple man. i see a speaker review from you, i click "Like"
minor comment on your videos, adding chapters would really help! :) also, your volume changes up when you change location, might be worth equalising them.
hardisj
hardisj
Reviewer
North Alabama
I am lazy. I was doing good with chapters but have grown tired of it so I stopped. :D :eek:
Volume changes; trying a new mic (lapel mic so I can stand up for a portion of the video). Lots of variables. But I agree. I'll keep that in mind in the next video.
Joecarrow
These reviews are so valuable! I’ve heard the HT12 and loved them. If we can figure out and address a few of these resonances I think they are going to beat some *very* expensive speakers if used with subs properly. These NFS measurements are invaluable for this, it’s not easy getting that resolution of data through other methods. I thought I read that ground plane set up properly can get close, and that seems like the only method really available to DIYers before now if we want more resolution on the whole system than a free space gated measurement.
abdo123
Brussels, Belgium
Wouldn’t the EQ eat up some headroom which really brings the sensitivity realistically to 88 dBSPL/2.83V which is more or less the industry standard?
The distortion measurements are quite good, the Speakers can work perfectly well for home cinema. I wish we had distortion measurements at ~110 dB to see whether it can really work as a poor man’s home cinema speaker!
hardisj
hardisj
Reviewer
North Alabama
At that level, masking will far override your ability to hear distortion. Lower volume is where distortion is more audible. Geddes talks about this in my discussion with him. I could provide the data but I personally think what you'd be better having is compression data. And, TBH, I've done enough here to characterize the performance of this speaker and just don't see the need to drop my other tests in order to re-evaluate this one for higher SPL limits. :)
tomtoo
Germany
Thats the great part of active design, it has not to eat up driver efficience for linearity.
napilopez
NYC
Wouldn’t the EQ eat up some headroom which really brings the sensitivity realistically to 86-88 dBSPL/2.83V which is more or less the industry standard?
I don't see why the EQ required for this speaker would dramatically alter headroom. That said, I probably should have said 'headroom on the cheap' rather than sensitivity on the cheap as my main point was that you're going to have trouble finding speakers that can get this loud with such good directivity for under $1000. Not that many decent 12-inch speakers in this price range!
abdo123
Brussels, Belgium
I get you, it’s just 102 dB @ 1m becomes 90 dB @ 4m, the later being a more realistic distance for a home cinema.
Joecarrow
Correct me if I’m wrong, but isn’t this also the kind of testing that’s a little easier for you and I to do with just a mic and some space, and not a whole NFS system?
hardisj
hardisj
Reviewer
North Alabama
And then add 6dB for having a second speaker and another 3-4dB for being in a room. :)
