DIYSG HTM-12v1 Speaker Review
hardisj
Reviewer
North Alabama
This is copy/pasted from my website. Therefore, there may be some formatting things that go awry when pasted here. Feel free to view the review natively on my site linked below. Otherwise, enjoy it here!
https://www.erinsaudiocorner.com/loudspeakers/diysg_htm12v1/
  • Tuesday, May 18, 2021
However, for those who want more - a detailed explanation of the objective performance, and my subjective evaluation (what I heard, what I liked, etc.) - please watch the below video where I go more in-depth.
Information and Photos
The DIYSG HTM-12v1 is a DIY design from Matt Grant which was/is available in kit form from DIYSG.
Note the distinction of this model is “v1” as there has since been an update to this speaker design which was released in early 2020. Therefore, this review is more for educational purposes and hopefully will help users and designers alike understand the objective performance in the highest resolution possible as current available measurements are a mixture of quasi-anechoic methods and thus have low resolution / high smoothing, insufficient to show problematic areas where anechoic measurements excel.
The HTM-12v1 is a 2-way loudspeaker featuring a SEOS-15 waveguide with Denovo DNA-325 and an Eminence Deltalite 12-inch woofer. (These specific parts could be different model numbers; this was the best information I could find and I will update this section if necessary).
A kit for a single speaker (including everything sans enclosure; except for front baffle) was approximately $330 (I think).
These speakers were loaned to me by their owner, who built them from the kit. There are no physical or electro-mechanical issues and this unit is a good sample, representative of what one would ideally build from the kit.
The reference plane in this test is just below the tweeter, per the designer, Matt.
CTA-2034 / SPINORAMA:
Early Reflections Breakout:
Estimated In-Room Response:
Additional Measurements
Impedance Magnitude and Phase + Equivalent Peak Dissipation Resistance (EPDR)
For those who do not know what EPDR is (ahem, me until 2020), Keith Howard came up with this metric which he defined in a 2007 article for Stereophile as:
… simply the resistive load that would give rise to the same peak device dissipation as the speaker itself.​
A note from Dr. Jack Oclee-Brown of JBL (who supplied the formula for calculating EPDR):
Just a note of caution that the EPDR derivation is based on a class-B output stage so it’s valid for typical class-AB amps but certainly not for class-A and probably has only marginal relevance for class-D amps (would love to hear from a class-D expert on this topic).​
On-Axis Response Linearity
“Globe” Plots
Vertical Polar (Globe) Plot:
Harmonic Distortion
Harmonic Distortion at 102dB @ 1m:
Near-Field Response
Nearfield response of individual drive units:
  2. 86dB at 1 meter (red)
  3. 96dB at 1 meter (blue)
  4. 102dB at 1 meter (purple)
Long Term Compression Tests
Parting / Random Thoughts
  • Subjective listening was mainly in the farfield at 3-4 meters in an open floorplan living room. Subjective listening was conducted at 80-95dB at these distances and occasionally higher. Higher volumes were done simply to test the output capability in case one wants to try to sit further away.
  • Toy Soldiers - Resonant in the 150Hz region, her voice pops through the mix ~1kHz.
  • Enjoy the Silence - Missing attack, vocals are a bit “behind” the mix; likely something in the 3kHz area.
  • Higher Love - Missing that strong snare attack that I really like about this track.
  • Soundstage drifts in width; i.e., “Magic” by The Cars has a mouth sound that should be on the left outside but instead is at two distinct spaces on the left; how does this match with the radiation pattern? Is the radiation uniform? Sounds varied. Looking back at the radiation pattern, this makes sense as you can see the radiation tends to shift in angle. For example, at 300Hz the radiation pattern is about 20° wider than at 500Hz before getting wider again at 800Hz to 1.3kHz and then narrowing another 20° above this and narrowing up until approximately 9kHz. This varying radiation pattern in my incredibly subjective opinion causes the soundstage to not remain consistent, meaning that if an instrument or vocal is at one place in the soundstage for the fundamental, it will be at a different location for the harmonic(s). YMMV.
  • Sensitivity averages around 94dB @ 2.83v/1m.
  • Obviously with an f3 of 78Hz and f10 of 53Hz, these speakers do need a subwoofer. Without the addition of a subwoofer you will find lack of fullness to tracks with low midbass (50-60Hz kickdrums, for example).
  • Distortion and compression are incredibly low. In fact, the lowest I’ve measured to date, besting the $3000/pair Klipsch Heresy IV.
  • No problem getting very, very loud in my large living room.
  • Voices don’t sound natural; FR is quite varied and some intelligibility is lost due to the 3kHz suck out.
Support / Donate
If you like what you see here and want to help me keep it going, please consider donating via the PayPal Contribute link here. Donations help me pay for new items to test, hardware, miscellaneous items and costs of the site’s server space and bandwidth. All of which I otherwise pay out of pocket. And, truthfully speaking, help me buy lunch and maybe take my wife and kid out for dinner now and again in an effort to “apologize” for spending so much time in the garage testing all these speakers. So, if you can help chip in a few bucks, know that it is very much appreciated. Alternatively, you can use the affiliate link on my site if you want to purchase these.
You can also join my Facebook and YouTube pages if you would like to follow along with updates.
hardisj
hardisj
Reviewer
North Alabama
Oh, here is a groundplane measurement I did as a sanity check to make sure the dip below 200Hz was indeed real. Ignore the GP results above about 500Hz because the speaker was not aimed to provide anything more than LF accuracy (if you know what I mean, you know what I mean). Also, the GP measurement was gated to about 50ms or so because the house was close. Normally I measure further out in the road but didn't see the need since I only was interested in 100-200Hz region. But I didn't. Therefore, you can see a bit of a rebound at the 25Hz mark that is due to a reflection from the house.
hardisj
hardisj
Reviewer
North Alabama
LOL, I said you might be the most hated or loved person over at AVS following this review.:)
Well, with as much time as I have spent measuring drivers for the DIY community, hopefully those folks know that I'm only providing my reviews as a means to help and I have offered my services free of charge for any future DIYSG projects.
richard12511
“Globe” Plots
Harmonic Distortion
Near-Field Response
Support / Donate
Fantastic dynamic capability(little to no compression of either kind and low distortion).
Directivity is also pretty good. I think with a little EQ this will be a very good speaker at most any volume.
johnp98
Very happy to see more DIY speakers being reviewed!
Very excited about this one as I happen to have a pair of HTM-12 (v2 though).
Here is my in room response that I get using a moving mic method:
Would be very curious if the new version could be reviewed. Or any other DIYSG speakers. Heck any DIY speakers in general!
Matias
São Paulo, Brazil
Where is the EQ to save the day??
johnp98
Yeah the normalized polar plots seem very impressive (probably because of the waveguide), so I do wonder if EQ is the way to go to get a flat on axis response as the DI is quite good.
johnp98
Also, FYI here is what they said about the changes in the new versions
"The HTM-12 is going to be getting some changes. The new model wll be switching to a Celestion compression driver. It will also be getting a new custom designed woofer, it's based off the deltalite but has a copper shorting ring in the motor, longer voice coil, new cone, dustcap, spider and surround, and perhaps most important to some of you no more silver ring around the outside.
The new woofer was actually intended for use in a new Fusion line but since those woofers were already ordered, the stock of the 2512's was running low and the HTM-12 was going to need changes to move away from the DNA-325 anyway it was decided to put the new woofers to use in the HTM-12 as the new Fusion designs may have been a long while out. The new Hyperlite-12 woofer does loose a little sensitivity (now 95dB) but gains about 10Hz of bass extension in the same enclosure and gives more midbass kick then the original Deltalite.
With a new compression driver and woofer the crossover has also been redesigned though it retains much of the same voicing as the original. The main change being that the crossover point has been lowered to 1250hz to give better directivity matching between the woofer and waveguide and some minor response adjustments that I feel give a cleaner presentation in the midrange and treble."
Source: http://www.hificircuit.com/community/threads/htm-speaker-kits.609/page-9
aarons915
Chicago, IL
This is basically what I expected from these. So many people talk about these and the other variations and always seem to talk about how loud they can go but does it really matter that a speaker can play at 120 db if it sounds like crap lol? I say focus on sound quality /neutrality before worrying about a speaker playing at 120 db...
q3cpma
France
Prime candidate for DSP, but that high port tuning (probably due to high PA woofer Fs) isn't very good, maybe even a bit too high for good sub crossover. Also, is it me, or does it lack a proper high pass filter that goes with traditional bass reflex?
napilopez
NYC
Horizontal directivity is fantastic. All this needs is a little EQ and you're good to go!
Thanks for the reviews -- you're killing it @hardisj
MZKM
Land O’ Lakes, FL
Cause it reminded me of it and it wasn’t in my current format, I decided to redo tthe graphs of the Klipsch RP-600M:
I know Audioholics measured them, but I wanna see a spin of the RP-8000F, as it didn’t show the 2kHz dip with as much severity.
richard12511
beaRA
To that end, is there an AVR/AVP that will let you apply manual PEQ to a full surround set? I suppose you could just let Audyssey/Dirac/ARC do it's thing full range on these, but I imagine PEQ based on anechoic LW would be better.
