DIYRM / Scott Hinson Multiple Entry Horn build
The dictionary definition of "error" is a "mistake". Unless we are talking about Danny Ritchie, or Zu Audio, or someone else who doesn't take measurements, then it is NOT an error, it is a tradeoff chosen by the speaker designer. It would be much more appropriate to simply refer to it as a directivity "mismatch" which is just a factual statement without any judgmental connotation.
...It is a disservice to suggest to them that basic design decisions are "mistakes".
In scientific writing the term error does not usually imply a mistake (eg by the designer in this case). Error is the difference (calculated by subtraction) between a measured value and a hypothetical ideal target. Or the difference between a prediction and the actual result. In curve fitting, for example, it is common to calculate the SSE (sum of squared errors) as a measure of GOF (goodness of fit).
In scientific writing the term error does not usually imply a mistake (eg by the designer in this case). Error is the difference (calculated by subtraction) between a measured value and a hypothetical ideal target. ...
Yes, I know. But that is not how the term " directivity error" is used, or at least I have never seen it used that way on ASR.
To me, that term is more apt for, say, a woofer and tweeter with significantly different directivity near their crossover point.
Fundamentally, the "waistbanding" effect in question is due to diffraction.
Had a date night with my wife and moved the speakers to our garden for a few hours. These sound absolutely fantastic in outdoor setting.
Definitely where my head is at on these. I'm not sure when I'll have space or time to build new speakers, but 3D printing a fancy horn seems like a good use of it. If some hero with the skills and software wants to simulate a really optimized, curvy sort of MEH design at some point, plebes like me can produce a perfect copy with .1mm precision at home, with no more strain on the brain than cooking a frozen pizza.
This is the sort of STL I would pay decent money for...
Solana v2.0 was released a couple of days ago.
I'm building three of Scott's MEH right now and am curious how you finished the horn section? Did you smooth the joint sections or maybe you didn't have to?
Near the throat adapter I applied epoxy repair putty to the corners and tried to follow the oblate spheroid to conical shape as smoothly as possible, and only light filling for small gaps on the horn corners.
Epoxy putty -> sanding block and a piece of L-shaped rounded corner trim molding, wrapped with a piece of sanding mesh to get into the corners -> repeat a few times.
When applying the epoxy putty, attach the throat adapter and put some cling film or other plastic between the horn and adapter. That way you can stuff the epoxy between the seam and protect the adapter part. Regular woodwork filler putty won't be able to hold on to the tight edge between the horn-adapter transition and will most likely chip off, happens sometimes with the epoxy also. (photo 2)
When doing this stage of the build, it's good to have a movable table/work light that you can shine from behind. Be careful no to sand the throat adapter!
The wood filler that I had for smoothing out surface scratches was absolute rubbish quality and was the main reason I had to re-paint these. When using the epoxy putty pay attention to the paint primer being suitable for that material, it's a serious pain the rear to strip paint from these. I'd avoid painting over the t-nuts, because when you install the woofers and tighten the bolts, it will probably crack the paint/lacquer around those.
Re-painted and enclosure lacquered. I'm not happy with that color, it cured to look like "public park trash can green", a lot different than the test pieces I made. And the paint already cracked, but now I can try to fix it with kintsukuroi. Won't be re-painting these ever again without a proper spray booth.
Looks great. I've been using a thick two part epoxy and will look into getting some epoxy putty. LOL at your color description!
