DIY WiSA Home Theater system
Hello,
Here is some update.
I have received my Logic Analyzer - Cheap one that connect to USB and work with Salae software.
I have managed to capture some I2S Signal from the RX board as follow:
Channel 0 is the Clock
Channel 1 is LRCLK
Channel 2 is Data 0
Channel 3 is Data 1 (which seems to be the same as Data 0)
But I am not sure of the settings:
However, I have been able to confirm that when changing the speaker assignment to each different position of a 5.1.2 setup and sending a "chime" via the application -> a signal is visible on the analyzer.
Would it confirm that all data are on one line ?
EDIT:
I was able to confirm the theory above:
I also ordered a small I2S DAC MAX98357 Mono D-Amp, after a piggy-back on the I2S signal and connect to a cheap speaker -> IT WORKS !
All the 8 channel work independently without issue and I can assign the speaker to each channel as I wish.
Next step: To figure out the function of the 18-ish remaining pins, even though most of them are not mandatory to make something out of this receiver... (Except if there is some kind of boot sequence from the DSP to Receiver)
(Sorry a bit messy)
Cheers,
Hello,
Some updates:
I found the UART Communication pins and could look at some logging from the RX:
There is details on the:
  • WiFi canal
  • The volumne in HEX format
  • the Mute 1/0
  • some details on the board origin (RW-34)
I have progress on understanding the pin-out (Refer to previous pictures for Pin 1 and 24):
Green are confirmed pins, white is expected and ? is unknown.
I am not sure why, I2C connection does not seems to work.
I am not sure on the next steps, do I need to know everything about the board or should I continue on integrating to speakers?
I was looking at I2S Digital amplifier and there is not that many on the market:
- MAX98357A - Super cheap but can only output 3W.
- A range of Texas Instrument (TAS58XX series) which seems to be a nice choice, some of them even include a DSP but it seems that TI tools are required for this:
- This project would almost fit perfectly my need and is almost all done: https://github.com/tonyp7/TAS5806M-Audio-Amplifier ->
- Another one on TAS5825M - https://github.com/Darmur/bassowl-hat
- And other small ones...
Hello,
Following my post in the I2S Amp thread:
I have received the draft design, from a hired free-lance, to use TAS5828M and I would like to get your opinion before sending it for manufacturing:
Would anyone would be able to cross check on the Smart Amp / Class-D amplifier before I place a 100$ order for manufacturing ?
Due to availability at JLPCB, I had to switch C2 and C3.
All the files are available : https://github.com/Glider95/TAS5828M--Audio-amplifier
BOM:
Any comment would be of great help !
Hey @Glider95
Glad to see your project alive and kicking
I am not knowledgeable enough to give you any advice on the PCB. It calls my attention to see all those corners but I know it is a controversial subject. Does your designer know it is a switching amplifier? Also, the amp chip output traces (the two in the centre of the chip), seem a bit unnecessary thin and long. How many watts can this output? Are you printing it on 2oz copper?
The evaluation board of the amp is very well documented with detailed schematics, BOM and PCB design, have you seen it? (screenshot below)
There is a sub Reddit called r/PrintedCircuitBoard that is all about people posting pcb designs and schematics asking for advices and review. I recommend you to post there, ASR population is all about buying, not too much real DIY going on here -except for speakers maybe :D
Good luck!
Edit: I read in another thread that it outputs 100W. If you plan to drive it that hard, I suggest you to check with a trace calculator how hot those traces can get and modify accordingly if needed
Hey @Glider95
Good luck!
Thank you for your feedback !
If you are referring to this strip:
I believe it used for cooling of the chip itself. I forgot where I read that but I remember something around that line.
As you mentioned in your edit, the chip is capable of 100W mono output. Upon your feedback and also received from the subreddit comments (posted as you advised ;)) , I believe I might have to oversize a bit the traces and input connector to handle up to 24V input power.
Personally, I don't think I will go up high in output power as the most consuming part of my speakers would be 2 ways bookshelf ( I am looking at this base build : Erikdidit - bookshelf - Video) for around 50W.
No, i refer to these ones below:
these traces carry the amplified signal, that if you push the amp and/or you have a difficult load, they can carry significant current. The traces as you have them are the thickness of a pin (0.2 mm maybe?) and relatively long. If you are using regular 1oz copper, i suggest to pay attention to it, and if too late to change and in doubt, consider 2oz copper, that is a game changer. Look how TI solves that:
The traces start thin, as it needs to be to fit the pads, but as early as possible they make them as thick as possible.
Probably i am exaggerating and there is no problem, but rememeber the motto: the copper is for free.
Regarding the thermal pad that you mention, what you have looks fine enough. If it was me and specially if you plan to put a lot of electronics in a small closed enclosure, i think that out of precaution i would leave provision for a small heat sink, that is, a couple of mounting holes to each side of the chip. In your case it should be easy as the thermal pad is on the bottom. (edit: hmm, i see your rendering that suggest the pad is on the bottom, but are you sure about it? the datasheet suggests it is on the top, but maybe there are different versions of the chip? anyways, if it is on the top, i would definitely redesign the board to add a heat sink, see the next post). Again, probably not necessary, but it is for free and the is no way back if you dont have them.
Cool that you posted it in reddit, will go there see what people suggest :)
I oversaw it before, but TI eval board indeed uses a heat sink, and not small precisely:
look at the mounting holes for it at the sides of the chip i like i was suggesting:
remember this is an evaluation board, made to be capable to bring the amp to its limit, but still, imo, better be conservative than to regret, specially if you have the space. The BOM of the eval board should detail what heatsink they use exactly to give you an idea (i did not check).
Hey,
Tell me more about what you are looking for, I will be happy to share what I gathered so far :)
I've gotten some more information on your post above, I'll try to get the module to work next, thanks
Hello all,
The amplification board is currently under rework to implement the different feedbacks I received from knowledgeable people. In the meantime, I am trying to look at the next steps of this projects which are the speakers of this surround system themselves.
After quite bit of research with these focus:
- Speaker design that can be 3D printed with possible fallback plan to traditional speakers
- Within reasonable budget & space constraints
- Parts procurable in this part of the world
I have come to the following shortlist that mostly gravitate around 3 drivers:
Front left & Right:
- Plan A: Homemade design in the same spirit vase as the one shared by Ringoton here but instead using Dayton TCP115-4 (Woofer) & Dayton ND25FA-4 (Tweeter).
- Plan B: Erikdidit - Budget speaker - Video - with ND25FA-4 which is slightly different tweeter than NHP25Ti-4 used by Erik as it is not available.
- Plan C: Hexibase - 3D Printed Dozer - Video
Central channel:
- DIYPerks - Center channel using TCP115-4 & 1" Dayton ND25FA-4 (Dayton ND25FN-4 not available)
Subwoofer:
- DIYPerks - Transmission line subwoofer that could be placed behind the TV or under the sofa. Is there a more suitable driver than 2*TCP115-4 for this ?
or
- Hexibase - 3D printed - 7th order subwoofer using 1*TCP115-4
Surrounds (Left, Right & Rears):
For the surrounds, I am planning to make them run on batteries so they can be really wireless. They would be charged by induction during the day and would just need to be placed around for movie nights.
- RD Design - 3D Printed - Sphere design but using Dayton PS95-4
or
- a similar sphere design using smaller Dayton PC68-4 which are half price compared to PS95-4.
All together, for all the drivers, it should come around:
- 240 USD for the option with PC68 surrounds & 2*TCP115 subwoofer
- 330 USD for the option with PS95 surrounds
For the amplification, I am planning to use the board created above for each speakers - it should come around 150 USD for 8 boards but I might look at simpler and cheaper boards for the surrounds.
It will remain the plastic for enclosure ( 40 USD for 4kgs - rough estimate), the power supplies / batteries+electronics & additional WiSA receivers.
Total: Should be below 700USD for 7.1 system with the possibility to add ceiling speakers later.
Any comment is more than welcome ! Again, I have no knowledge on speakers and I have just built this trying to use existing things from the open source community !
Does it make sense to continue or should I just go for a 2nd hand built system ahah...
These people are selling the modules at 4$, but you'll need to convince a few friends to reach the MOQ. I would be one if you are in Europe
I came across this website before but I was doubting it is legit...
However, after more research, the seller is "Enclave" located in Hong Kong and there is indeed an audio company called Enclave and selling WiSA equipped speakers.
I have contacted them via their support, will update on the answer !
Hello,
Here is some updates on the I2S Class-D amplification board:
Top
Bottom
3D Render
And here is the BOM:
One idea would be to move C2,C3 a bit more left (view from top) so there is enough space to a place a "large" heatsink if case big output is needed.
Any feedback would be greatly appreciated, I will share all the files as well once validated :)
This is really great work and I hope you continue with this project. I too am in the WiSA ecosystem and I hope the technology continues to progress.
Hi Glider95, nice progress!
I have a question about the transmitter part. Do you now if the I2S lines are exposed in the SoundSend puck? I was thinking on buying a SoundSend (easily available) + some WiSa receivers to use some passive speakers I already have, but those have been impossible to find anywhere. I began to think if maybe there's a way of using the SoundSend essentially as a cheap-ish surround processor and tap into the I2S signals for a wired system (ironic, I know).
Thanks!
Hey,
I paused this project a little bit for now. I bought a traditional wired 5.1 but I am still keeping this project on the table.
I just saw that WiSA has been absorbed by another patent company, seems to be some change in their product line and how they want to market it? (I.e: A new Android app for wireless audio)
Thanks!
There is quite a few pins exposed and might be the J1 or J3 are the one that you are looking for but I would expected I2S signal to be labelled with CLK or similar...
However, I am pretty sure that the I2S signal is available somewhere on the 40pin of the WiSA Transmitter in similar fashion than the 24pin receiver.
Another interesting information is that Espressif confirmed that ESP32-C5 is now in mass production.
This tiny board is capable of 5GhZ WiFi which would have enough bandwidth for 8 channels. As far as I understand WiSA proprietary technology is actually using these frequencies.
As well, the latest WiSA E products are also relying on Espressif boards: WiSA E Endeavor
Some preliminary feedback on this board - see ESP32-C5 preliminary video:
Thanks Glider95! I have limited space so a normal receiver would be almost impossible to use for my case, that's why I was thinking on using it as a poor-man's (limited-space-man's?) alternative to a receiver. Since it decodes Dolby formats and can apply bass management/delays/etc. it could be an option as long as the I2S signals can be tapped into.
One thing I haven't seen confirmed anywhere is if it supports and processes multichannel LPCM audio. I've only seen it advertised as supporting Dolby formats and I think it should support LPCM too but a confirmation would be nice.
Thanks!
Thanks!
Hey @nullpointerninja ,
I am sorry, I have not came back to you.
Did you manage to progress on your question?
I look again at this idea of using ESP32-C5 for wireless transmission and do a Gemini Deep-research around it based on what I have worked on before:
Gemini Deep-research summary:
Key components for success are the Texas Instruments TAS5828M amplifier for each speaker and, crucially, the Espressif ESP32-C5 microcontroller. The ESP32-C5's dual-band Wi-Fi 6, particularly its 5 GHz capability, is essential for creating a stable, low-latency audio network, avoiding the interference-prone 2.4 GHz band.
The primary engineering challenge is achieving the microsecond-level synchronization required between speakers to prevent audio distortion. Standard networking protocols are insufficient for this task. The proposed solution is a custom protocol built on the hardware-based
IEEE 802.11 Timing Synchronization Function (TSF), which provides a shared, microsecond-resolution clock across all devices on the Wi-Fi network.
The system architecture is a "Hub-and-Spoke" model. A central Hub, built from a powerful Single-Board Computer (like a Raspberry Pi or Orange Pi which has HDMI eArc capabilities) and an ESP32-C5, will manage the network and transmit the audio. Each speaker, or "Spoke," will consist of an ESP32-C5 and a TAS5828M amplifier.
Handling Dolby Atmos requires offloading the complex and proprietary decoding from the speaker nodes. Two paths are possible:
- LPCM Transport: Use a commercial source device (like a Blu-ray player or Apple TV) to decode the Atmos track and output a standard multi-channel LPCM audio stream. The DIY system's sole job is to transport this uncompressed audio perfectly.
- On-Hub Decoding with Cavernize (@VoidX): For a more integrated solution, the open-source Cavern audio engine can be run on the Hub's processor to decode the Dolby Atmos bitstream directly before transmitting the resulting LPCM audio to the speakers.
Development should be done using Espressif's official ESP-IDF to get the necessary low-level hardware control, and a phased implementation is recommended to manage complexity.
So as you can see... not an easy task to tackle:
- Cavernize does not seem to support real time decoding - maybe could be worked around with source buffering ? (@VoidX , is it due to high resources required ?)
- Despite OrangePi advertizing eArc, nobody seems to have made it work !
- A "full" real-time transmission protocol to create....
Flow would be:
TV --- eArc --> OrangePi with Cavern ---> I2S --> ESP32-C5 emitter --Wifi 5GhZ ---> ESP32-C5 receivers
or without eArc
OrangePi as media center with Cavern ---> I2S --> ESP32-C5 emitter --Wifi 5GhZ ---> ESP32-C5 receivers
Cavern Is Windows only, it won’t even run on a pi.
