I'm building a DIY ultrasonic vinyl record cleaning setup. Using a Vevor ultrasonic tank and BBQ rotisserie motor to clean stacks of records in a cleaning solution. More details at the bottom.
My problem is the motor turns a horizontal shaft, but sometimes the records slip and don't spin through the cleaning solution. I have 1/2 inch rubber spacers, 2 inch diameter, between the records, and compress the stack before connecting to the motor drive. I have done 5 batches so far, but need to improve the grip between the records and the shaft. The shaft is 1/4 inch all thread with shrink tubing covering the metal threads. Any suggestions?
My setup:
Vevor 15 liter ultrasonic tank (Amazon)
BBQ rotisserie motor (Amazon)
All thread shaft with shrink tubing liner, fits OK but not tight.
I'm doing batches of 10 - 12 records each batch.
Rinse bin. Distilled water and a few drops of wetting solution.
Microfiber towels to hand dry.
drying rack- dish rack with pvc spacers.
Cleaning solution is distilled water, alcohol, Triton X100 detergent. Heated to about 90 degrees F.
Any suggestions or improvements?
My setup:
