Hi everyone, merry Xmax!!
I’ll try to keep this as short and clear as possible so I can explain the situation, my needs, and ask for advice.
Room: 13 × 12.5 ft with 9.8 ft ceilings (does not open into a larger space when the door is closed)
Usage: Music and movies. We listen to a lot of bass-heavy music since this room also functions as our home gym, but we also watch movies and TV series.
AVR: Denon X-2700H
LCR: Monolith 365C + 365T
Surrounds: Kenwood Series 21 satellites
Subwoofer: (don’t laugh) Logitech Z-5500
I converted it to passive and connected it to a NEC A-230E amp. I believe the NEC has a preamp stage inside, because when I tried to power the Logitech sub with another amp, it didn’t produce any signal at all (not sure why).
I previously owned dual Monolith 13s, but I sold them because they were huge and we needed the space for other equipment in this multi-use room. Now I’m stuck with the Logitech sub, which heavily distorts during movies or when I turn it up (obviously there’s no proper limiter).
What I want to upgrade
I want
more bass. I’m not necessarily chasing infrasonics, but above 27 Hz (or even 31.5 Hz) I’d like to reach
SPL levels of 120 dB+.
Limitations
Maximum subwoofer depth:
19 inches
Prices for dual subwoofer options (Europe)
- Dual SVS SB-1000: €1,500
- Dual SVS SB-2000: €2,100
- Dual SVS SB-3000: €2,800
- Dual SVS SB-5000: €5,600
- Dual SVS SB-17 Ultra: €7,400
- Dual Arendal 196 1S: €2,000
- Dual Arendal 1723 1S: €3,000
- Dual KRK S12 G4: €1,300
DIY option
I could also go the DIY route with these sealed kits, powered by a pro amp:
Amp: Behringer NX6000D – €460
Questions
How do these Ultimax sealed kits (15 or 18) compare to the other subs on my list?
For example, could
dual UM18s provide more SPL from ~30 Hz to 80 Hz compared to the
SVS SB-17?
If the CEA-2010 data I found for the Ultimax 18 is accurate, it seems this driver can easily outperform the SVS SB-4000. However, I can’t find CEA-2010 measurements for the newer SVS models (SB-5000 and SB-17).
Any advice or real-world experience would be greatly appreciated.
